Need Exhaust Help?? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 07:22 PM   #1
bigbearz's Avatar
Exclamation
Need exhaust Help??
I am doing my garage heater right now and ran into a snag. I went to go out the side wall of my garage and where the vent would be is into the soffit... I found a new location that I can get it straight out 24" past my eaves, but it will be 24" from my house. Is this OK?
Can someone help?
bigbearz is offline   Reply With Quote
Old 03-20-2011, 08:54 PM   #2
No. Take it out the roof like it's supposed to be.
Old 03-20-2011, 09:23 PM   #3
bigbearz's Avatar
I can't I have a bonus room above my garage. I bought to side vent kit? is this not good? its a 45,000 Mr.Heater big maxx.
Old 03-20-2011, 09:40 PM   #4
If the heater is approved for side wall vent and you have the correct kit then it can be done. Any way to take it another side? I think the wind is going to swirl in that spot and the moisture laiden & acidic exhaust will cause problems with the garage and house.
Old 03-20-2011, 10:50 PM   #5
bigbearz's Avatar
no unfortunately.... can the exhaust be bent down and through the side I originally wanted which is wide open? it would be a 4" drop about and then out??
Thanks for your help by the way
Old 03-21-2011, 06:12 AM   #6
It has to slope upward. You could lower the heater 5".
Old 03-21-2011, 08:02 AM   #7
bigbearz's Avatar
Going to try that, lowering it 6 or so. I was trying to avoid that so that the heater doesn't become a head obstacle in the garage. thanks for your help, I will see if I have the room.
Old 03-22-2011, 10:15 AM   #8
bigbearz's Avatar
Marty, thanks for your help.. I got the unit lowered another 7 inches and everything works fine going out the side now. It is still about 7.4ft off the ground so the clearance is still good and the exhaust is proper.
whole house exhaust fan anybody gailquilter2 HVAC 14 06-29-2012 08:42 AM
Dryer exhaust/Bathroom exhaust fan nclooten HVAC 4 11-09-2009 10:45 AM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 06:53 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
