Old 03-20-2009, 05:50 PM   #1
Need DIY Duct Cleaning Pointers
Has anybody had any luck doing this for themselves. I have an open basement, exposed ducting. Wondering if this can be done
Chemist1961 is offline   Reply With Quote
Old 03-20-2009, 06:19 PM   #2
hvaclover's Avatar
Requires specialized equipment unless you feel like disassembling all the duct sections and clean by hand with a vac.
i know one guy who tried. His ducts whistle all the tunes in the Sgt. Peppers Beatles album when he put it back together.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 03-20-2009, 06:34 PM   #3
Thanks HVL
Was thinking about pulling a 6" chimney brush through some of the heat runs, but I expect the issue is the returns not the heat ducts.
No DIY gadgets out ther for this project yet? I had them done before but wasn't here to watch. Is it a big floppy rotary brush?
Old 03-20-2009, 10:22 PM   #4
Hvac Pro
The only real good way to have it done is with the larger full size vacuum truck and not the smaller portable type that they use in a van. The more professional companies blow compressed air thru all the vents at the same time. I would cut an access hole in the return duct and inspect it myself. If your air filter is not getting dirty very fast then the ducts are probably okay. Beware of the low $$ cost companies as they usually do a blow and go routine. You get what you pay for and have to watch them.
Old 03-20-2009, 11:25 PM   #5
hvaclover's Avatar
For sure
DIY Air Duct Cleaning... How to? singforsupper HVAC 5 10-09-2008 01:06 PM
Flex Duct Advice ssporty21228 HVAC 4 07-23-2008 09:28 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Air Duct Cleaning Machine BigC General Discussion 1 07-29-2006 09:15 PM
duct cleaning mcgina HVAC 2 07-10-2006 07:29 PM
