Old 10-19-2009, 01:02 PM   #1
Default Need to change attic heater - options?
Hi there!
Looking to replace my current heater in my attic bedroom. I live in a ranch so upstairs bedroom is a converted attic. Room size is about 40ft x 15ft. I currently have an in the wall vented gas heater that is 1000 years old. The efficiency on it is terrible and now the pilot light goes out within 24 hours of running it. The unit is so old the gas & electric company aren't even sure how to light it, let alone fix it so I think it's time to replace it.
I'm looking for a simple option that won't break the bank. As a single mother I will not have the ability to have someone come in and do this for me start to finish so I'd like to do as much as I possibly can myself before asking for help.
Question is for the space (~500-550sq ft) what should I use?
Stay with the gas heater or swap to electric? This is the only gas needed in my home - for this one heater so it would be nice to eliminate.
But if I do go with another gas - Vented or non vented? difference?
If I swap to electric, will a 120V continue to flip the breaker? I have a small space heater now downstairs that does this constantly when on higher wattage. Will I need a dedicated breaker for this? How much of a nightmare is it to run 240V?
I was even considering 2 small wall heaters because the room is divided by a half bath, but again I don't want to have to be in the cellar flipping the breaker all the time. This would be an ideal option though because of the length of the room. Since it is a bedroom the heater will not be used much other than to maintain a low temp. I'm hardly ever up there, only to sleep and I maintain temp around 63-64 to sleep.
Thanks in advance for any feedback/help!
Lisasha3 is offline   Reply With Quote
More On This Topic
A space heater can save money on gas and electric bills because it heats only a small area and efficiently converts almost all of its energy into heat. However, heaters can pose a serious danger from fire and toxic air pollution. Reduce these risks by... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
I'm Jay Donnelly for Expert Village and today I am going to show you what you might need in case of a flood emergency. Okay the next step is house preparation. Secure your house. You want to go around your house and you want to shut off utilities such as... Read More »
Okay, so we have finished cleaning out the hole that we're going to be using and now Rudy and I are going to organize inside of the shanty. Some of the important elements and some of the amenities that might be available to you in a portable shanty are... Read More »
Heating & Cooling for Attic addition. ddave23 HVAC 1 09-01-2009 10:42 PM
Attic venting options Bob_T Roofing 5 06-20-2009 07:54 PM
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 8 04-24-2009 08:40 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 07:40 AM
Bosch tankless water heater install, questions... Zel1 Plumbing 0 12-16-2008 05:49 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
