Need A/c Education--ASAP - HVAC - DIY Chatroom Home Improvement Forum
Old 08-31-2009, 06:22 PM   #1
Exclamation
Need a/c education--ASAP
Hi, I just bought and had installed a new Trane energy efficient heat pump and air handler in my condo about two weeks ago. I was having trouble with my old Carrier leaking freon, and was told by the contractors I was working with at the time that it needed to be replaced. I shopped around a lot before going with my current contractor and deciding on the Trane unit. 5 days after installing the new unit, it stops working again. It turns out that I have to run a new line set because the new a/c still won't hold a charge. My freon lines were run under the concrete slab foundation and not through PVC. My A/C contractor is telling me he doesn't think he can run the new lines through the crawl space (which is the only fix my HOA will allow) because he will have to run more than 100 ft of line. HOA will not let me move the A/C unit to my patio; it has to stay on the end of the building. Can anyone educate me on a/c line sets, maximum length, etc? I'm caught between my HOA and my contractor. They say it can only be done this way, and my contractor is ready to walk. There has to be a solution to this problem....I've been living in Phoenix, AZ, with no A/C since July 26th and I'm miserable!!!
devano78 is offline   Reply With Quote
Old 08-31-2009, 07:04 PM   #2
An old Tradesmen
Rewards Points: 6,464
Have your contractor contact Trane.
Have him make a drawing of the way the line will run. Fax it to Trane, and Trane's engineers will tell him if he has to do anything special. And what size line set to run.
There will be a loss of capacity. But it may not be much.
PS: When Trane faxes or calls him back. Make sure your contractor writes down the name of who he is talking to. Or who approved it.
Then you have full warranty, because Trane approved it.
Old 08-31-2009, 07:08 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
You might look at the istall instructions about line set length and if you can't find your answers you need then I agree with Been get Trane involved
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-31-2009, 07:36 PM   #4
Thank you! I talked to the contractor after reading your posts and he says that it's no problem to talk to Trane. He's already done it. We just have a fire wall that we have to get access through (unfortunately my condo is between fire walls on either end) and I have to locate the building plans at the hall of records to get it done. He and I will be crawling into the crawl space Wednesday morning to get a better measurement and formulate a plan. Thanks again for the recommendations. Any others will be appreciated!
Corian sinks--need advice! Asap! Please! donnatella General DIY Discussions 10 05-15-2011 11:37 AM
Please respond ASAP deerhunt1985 HVAC 1 07-22-2009 11:50 PM
Need advice for new heating system ASAP aok HVAC 9 02-18-2009 02:45 PM
oatey thread sealant ASAP smallcrpt Plumbing 6 11-20-2007 01:06 AM
H20 line broke, need advise ASAP! joe3534 Plumbing 2 07-03-2007 09:40 AM
