Need Bryant Plus 80 Circuit Board - HVAC - DIY Chatroom Home Improvement Forum
Old 12-11-2010, 04:03 PM   #1
I'm in need of a new circuit board for my Plus 80. Is there an online source for them?
The only markings on the board are:
1012-83-9402B
HSCI
9526 A E (on white stick-on label)
New edit: Didn't notice the part no. on the board's cover. HK42FZ011. Found a few hits, but would still like advise on reputable source.
tbzep is offline   Reply With Quote
Old 12-23-2010, 10:33 AM   #2
Found a used one on eBay. I put it in last week and it's still running great.
Old 12-29-2010, 10:15 PM   #3
1012-83-9402B
HSCI
what were your simptoms. I have the same unit and am having problems . Thanks
wood man is offline   Reply With Quote
Old 12-30-2010, 01:14 AM   #4
I was getting error code 31. It would try to start, but would quit at various stages of the startup proceedure. Sometimes the draft inducer would barely turn before it stopped. Sometimes it would go all the way through igniter heat-up and would stop when the gas kicked in. Sometimes it would even light the burners for a few seconds. I was able to borrow one from another unit and it worked, so I knew I needed the circuit board.
installing backer board over particle board bob mac Flooring 6 07-16-2013 04:15 PM
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 11:50 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
bryant inducer board part number? boomerbaird HVAC 3 01-03-2008 06:54 PM
