Need Advise Hot Water Heat Vs Steam Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2007, 07:34 PM   #1
Need advise Hot water heat vs steam heat
Hi guys, I am looking towards changing my heating system to hot water heat. Looking for pros and cons on both systems. I know hot water heating system is more efficeint. Thanks, also what goods brands are out there?
Okay, let me word this a little better:
I got quotes on a replacing the steam boiler ($4000.00)
Replacing the steam boiler, with hot water boiler and installing baseboards throughout the house ($6,500.00) 1,600sq feet house.
helpless handyman is offline   Reply With Quote
Old 10-30-2007, 10:29 PM   #2
Rewards Points: 380
Hot water boilers have a couple of advantages over steam in my opinion. Probably the formost is that you can adjust the water tempurature to match the outdoor air tempuratures allowing you to only heat the water to the temp you need to heat the house at differing outdoor temps. (This can be done automatically with the right outdoor air tempurature recorrect controller)The hot water rads are easy to control and often less troublesome than steam traps and avoid some return problems in older gravity sytems. The downside with either system as I see it is no option for A/C. Just an opinion.
HVACDave is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Steam Heat still making banging noises helpless handyman HVAC 101 01-04-2008 03:43 PM
change steam radiant heat to outside wood water heat Monteu HVAC 5 02-13-2007 11:19 AM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 08:57 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
