Need Advice On Two Adjoining Bathroom Fans - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2009, 08:17 PM   #1
Question
Need advice on two adjoining bathroom fans
So I have two bathrooms next to each other. They are both on the outer edge of the house (e.g. can exhaust through siding).
But I'm getting mixed answers on how to handle the two fans.
-Can bathroom fans exhaust to a side wall? Or is this a no-no? One bathroom's vent would be about 3ft long to the wall. The second bathroom's vent would be would be a bit longer (6ft?). I just had a new $6k roof put in, so I'm hesitant to put a roof vent on it. (Previous owners put it on, its an old farm house so it didn't have a fan).
-If venting through the wall is a no-no, can I:
(a) Install 2 separate fans, but T them into one roof vent? (or one wall vent?)
(b) Install an inline fan in the attic for both bathrooms?
With Option (a), would bathroom 1's exhaust get pushed into bathroom's 2 if only one is on?
HautingLu is offline   Reply With Quote
Old 09-08-2009, 08:49 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Venting through a sidewall is ok as long as the exhaust is 7' above a sidewalk of the exhaust does not exhaust into an area such as a patio, common area or such
If you are venting to a side yard you should be ok
Use a dryer vent as a termination to the exterior
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-08-2009, 09:09 PM   #3
Thank you! This is on the 2nd floor, so no sidewalk nearby.
The 1st bathroom duct would be 4ft to the wall, the 2nd would be 10ft. If I can't find an inline fan locally, I'm leaning towards 2 NuTone fans, with ducts running parallel towards the wall, and having 2 dry-type exhaust fans.
Bathroom fans, heating, etc lofar Remodeling 4 07-08-2009 12:44 PM
Venting new bathroom fans gillm HVAC 2 06-04-2009 10:36 PM
Bathroom exhaust fans PirateKatz HVAC 7 11-18-2008 03:09 PM
Replacing pipes in bathroom, need advice Steelmesh Plumbing 7 11-04-2008 11:30 AM
Multiple bathroom exhaust fans dpreznik HVAC 17 08-30-2007 12:09 PM
