Old 10-14-2008, 07:51 PM   #1
Need advice on a Thermostat
I am looking for a better programmable thermostat. I currently have a lux 20 dollar model. I have seen a few with the outdoor reset and was wondering these models are worth their price. Also, are there any models that have dual sensors (indoor) that I could place a remote sensor in another part of the house that would call heat? I have a single zone mono-flow and splitting the zone is a quit expensive. (I would get a few TRVs installed to balance the system) Thanks
fishmanflats is offline   Reply With Quote
Old 10-15-2008, 07:13 AM   #2
An old Tradesmen
Thermostats don't really have outdoor reset.
Some can use an outdoor stat to lock out aux, and heat pumps.
Several can use a remote stat, to control heating and cooling.
Depends what all you want it to do, as far as if its worth it or not.
Old 10-15-2008, 10:25 AM   #3
Unless you have an HVAC unit that can use the capabilities of an energy efficient thermostat you are better off staying where you are.
The only exception to that would be a 7 day 4 event programmable one that will allow you to program for each day of the week. That being said if you work regular hours on Mon-Fri then even these will to little for your energy consumption. In this case a 4 event 5-2 would do where you could program the work week to lower the temperature of your system when you are gone.
Having the remote sensor will only give you information and is not a replacement for a zone system.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Totaline thermostat trouble shooting Goldwing93 HVAC 3 07-30-2009 11:35 PM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
