Need Advice On Sealing HVAC Ducts - HVAC - DIY Chatroom Home Improvement Forum
Old 04-30-2008, 11:37 PM   #1
Need Advice on Sealing HVAC Ducts
I really need some advice on sealing HVAC ducts. I'm having a contractor put in a whole house fan. He has to disconnect and move some HVAC ducts in order to do it. He said that he would use metallic tape to reconnect and seal the ducts (I'm assuming they're UL 181 tapes).
I asked if he would use any mastic sealant and he stated that it wouldn't be necessary. I'm a bit concerned since the ducts presently have what appears to be mastic sealant over the 181 tapes.
Your help and advice would be appreciated on how to ensure that duct connections are properly sealed?
fatherlu is offline   Reply With Quote
Old 05-01-2008, 01:54 PM   #2
coolmen's Avatar
ul approved metal tape I use all the time. I see no problem
coolmen is offline   Reply With Quote
Old 05-01-2008, 02:30 PM   #3
Registered User
Termite's Avatar
Foil tape will adhere to a clean surface so well you will have to cut it to get it to let go. I don't see much need for mastic.
Old 05-01-2008, 03:32 PM   #4
Can you advise on mastic tape? Is mastic tape typically better than foil tape?
Also, what about putting mastic tape on first then foil tape on top of mastic tape?
Old 05-04-2008, 10:23 AM   #5
coolmen's Avatar
I like tape do to if I ever have to take it apart tape will come off easyer then mastic. Just use one or the other. to use both is just a waist of time and material (Overkill).
Old 05-04-2008, 11:43 AM   #6
Thanks for all the good advice.
A follow up question for using foil tape. Is it advisable to double tape or just go around once?
Old 05-04-2008, 01:23 PM   #7
coolmen's Avatar
tape it once.and if you feel air leaks then tape it an extra one or two or three or four on and on on on on o n ...././.l[]lor]-3o-]6o35-6o5-747k[p7kp654k58'5k5'p8k58'5k765'p5k7'p8k5'p8k58'pk you get it,
Do I need a HVAC return vent in basement? westing HVAC 13 04-03-2014 02:43 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
Questions about re-routing ducts in ceiling. Please help! xe0s HVAC 6 04-30-2008 08:38 PM
Weird HVAC configuration need your thoughts Rikky HVAC 2 09-10-2007 04:11 PM
Using PVC ducts instead of standard ducts robertmazzo HVAC 3 10-05-2006 05:26 PM
