Old 12-12-2009, 11:50 AM   #1
Need advice on odd cold air return size
The opening for my cold air return is an odd size, 11 5/8 by 19 1/4. The height I can change because it is drywall, but the width is fixed between 2 studs.
What would be the correct size return grill for this opening? 12x20 seems too wide and 10x20, or even 11x20, seems too narrow.
TIA
angrydot is offline   Reply With Quote
Old 12-12-2009, 02:23 PM   #2
An old Tradesmen
12X20 should be fine. As long as the screws can grab a hold of something.
Tags
grille return size
What Size are Return Ducts Usually K.M.G HVAC 33 09-26-2009 08:08 PM
Advice on current NEC codes to clear up wire size and service issue DIYALLTHETIME Electrical 2 03-05-2009 07:24 AM
cold air return ponch37300 HVAC 9 02-15-2009 10:55 PM
Cold air return klein HVAC 1 01-07-2009 10:09 AM
Help with return and supply size XHornet85 HVAC 9 09-17-2008 12:13 AM
