Need Advice On A New Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 05:53 AM   #1
Rewards Points: 95
Need advice on a new furnace
I have a 78 year old converted coal gas forced hot air furnace that I am planning on replacing.
I can't replace the blower/burner so the whole thing has to go. I got one price for a Trane xb90 125,000 BTU for a 3500s/f house that is 3 bricks thick, insulated attic and all new windows... for $7900. This includes removal of the old monster and connecting to the old ductwork....a full installation.
I got one other price of $13,000 from someone who said I need twin units. I am near Gettysburg, PA. These prices seem high to me based on research I've done.
Also, I've read good and bad things about Trane and about the XB90. I would like to pay extra for a good quality, long lasting furnace. Any suggestions on brands and models would be greatly appreciated as then I could go find an installer that carries that line.
Thank you very much,
IDIMyself is offline   Reply With Quote
Old 02-02-2013, 06:59 AM   #2
An old Tradesmen
Rewards Points: 6,876
See if you can find a model number on the gas burner. if not. Then make sure no other appliance is using gas. Turn the thermostat up so the gas burner for the furnace comes on, and clock your gas meter. this will tell you how much gas/how many BTUs it is inputting to heat your house. Then you know that you don't need any furnace above that size.
A load calc is the best way to find out how big of a furnace you need.
Have you contacted Haller Enterprises? I think they do work in your area.
Old 02-02-2013, 07:14 AM   #3
Rewards Points: 95
The current furnace is fairly cheap to run. I'm on a budget plan of $156 a month and I keep the heat at 68F. But the burner was making a boom sound when it ignited and so I had it cleaned out by a pro. Now it's just not coming on often enough. The house is 63 inside. I'm worried that the thing is on it's way out. I would love to just replace the parts in the photo below...I'm going to start a new thread looking for this part. There has to be an antique furnace parts person somewhere. It's dated 1948. I'll check Haller. Thank you
Old 02-02-2013, 07:35 AM   #4
An old Tradesmen
$1872.00 isn't bad for a large old house, if your water heater also gas.
Old 02-02-2013, 08:00 AM   #5
Rewards Points: 95
I know! And yes, I have an eighty gallon gas hot water heater. I don't want to replace this thing...I take really good care of it and oil the blower motor once a month and vacuum it out in the summer. Plus there's practically no parts to break (except the main part that I'm looking for!)
Wouldn't another brand of old conversion burner work?
Old 02-02-2013, 08:19 AM   #6
An old Tradesmen
And be just as old and hard to find parts for.
Old 02-02-2013, 09:32 AM   #7
MarginallyQualified
Rewards Points: 2,464
Which part? The one the screwdriver is pointing at?
If so... a competent gas burner mechanic should be able to adapt one of the more modern operating/PS valves into that set up.
Old 02-02-2013, 10:35 AM   #8
Rewards Points: 95
Well I was imagining a shiny new one in a box sitting on someone's shelf somewhere
Old 02-02-2013, 10:38 AM   #9
Rewards Points: 95
Nothing is broken now but when I had the furnace guy over to clean it he said that I should think about getting a new one because they don't make parts for it anymore. I hate to replace the entire furnace because the blower is huge, the box is huge and the ductwork is huge... and it all works so well heating this huge house very nicely (and cheaply too!)
Old 02-02-2013, 11:09 AM   #10
MarginallyQualified
....he said that I should think about getting a new one because they don't make parts for it anymore...
and he's learned the hard way that patching up old stuff doesn't pay as well
I hate to replace the entire furnace because...
eventually...
Old 02-02-2013, 11:39 AM   #11
An old Tradesmen
Actually, it can pay better then fixing newer equipment. Get to charge for all the phone and internet time of trying to find those old parts. 700 bucks to fix one is not uncommon depending which part is out.
Old 02-02-2013, 10:30 PM   #12
Rewards Points: 610
Try a commercial boiler company..they should be able to replace the old with new parts to provide proper input to burner...unless there are code compliance issues with doing that..not sure but, I don't think so.
techpappy is offline   Reply With Quote
Old 02-03-2013, 08:26 AM   #13
Rewards Points: 95
That's a good idea because someone just said that there are lots of oil burners out there. I know converting from oil to gas is possible because I've had someone do that before.
Thank you!
Old 02-03-2013, 01:52 PM   #14
Rewards Points: 610
I wasn't referring to installing an oil burner OR replacing an oil burner...you have a big old gas burner with gas pressure regulator, pilot assembly and controls which are very similar to some commercial boilers which utilize atmospheric burners..therefore should be able to install new parts in place of old...your burners are likely cast iron and will still be OK as long as they are cleaned out every couple of years..that means lifting them out, inverting and tapping/vacuuming then re installing....Unless atmospheric burners have gone the way of the DODO bird then should be doable.
BTW that boom was likely due to dirty burners resulting in a delayed ignition..They say that Cleanliness is next to godliness..in this case dirty burners could put you next to Godliness if you know what I mean....keep those burners/pilot assembly clean!
Old 02-03-2013, 02:39 PM   #15
Rewards Points: 95
Gotcha!
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
New Furnace Install AustinPorsche HVAC 1 05-12-2011 10:16 PM
wood furnace advice paul1969f HVAC 18 10-24-2009 12:07 PM
Need New furnace advice. Unregistered HVAC 3 10-23-2006 09:13 PM
