#1 |
need advice - filter size doesn't match air handler spec
hi,
i have in the attic a Trane air handler several years old. what's weird is that it says 20X20X1 for the filter. but every 3 to 6 months i have to squeeze in a 20X20X1 filter very very hard and sometimes even damage the pleated filter. the length is OK but it's too wide. i took measurements of the pleated filter and it's actually a little smaller than 20 inches already. is 19X20X1 possible to find? or is there something i could do to make it easier to force in a 20X20X1? is this normal or is there something wrong with Trane air handler? Thank you. borrowed a picture from internet and added the numbers to show the width is giving me the trouble. Last edited by diybeginner123; 03-28-2012 at 04:39 PM. Reason: picture added |
#2 |
An old Tradesmen
Remove filter, an measure what size the bracket is. may be able to use an 18X20X1.
#3 |
If beenthere's suggestion doesn't work...
In my neck of the woods we have air filter manufactures that seem content to make up small lots (10) of what ever sized filter you want. For a 1" width filter in your dimmensions with a pleated paper medium it's only $8.00 each. Might be worth a local phone book check to see. |
#4 |
retired elect/hvac/plumb
Cut the filter down and staple end back on
"facts" have no relevance to this discusion To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Posting from a concrete bunker under a non descript barn |
#5 |
HVAC Tech/Owner
On that airhandler, Check to make sure there are no screws holding that return plenum on that extend into the filter rack.....or change to filter grille's.
| The Following User Says Thank You to Technow For This Useful Post: | plummen (03-29-2012) |
#6 |
19-1/2 x 19-1/2 x 1
Very common.
Filtration / HVAC & Indoor Air Quality Solutions |
#7 |
thank you all! i finally went back to the attic to take measurements and it's 19 3/4. so 18X20X1 is too small. but i'll try to find 19 1/2 X 19 1/2 X 1. i can't find it in local home depot though. i forgot to check what Technow suggested and will do so next time when i'm up there.
| Display Modes | |
| Looking for advice on rafter size for shed..... | mlf | Roofing/Siding | 5 | 06-29-2011 09:00 AM |
| Need to match breaker size to oven amps? | dbrew | Electrical | 17 | 02-23-2011 08:21 AM |
| Baseboard Heater Size Advice | nightheron | Electrical | 4 | 12-05-2010 08:33 PM |
| Need advice on odd cold air return size | angrydot | HVAC | 1 | 12-12-2009 02:23 PM |
| Advice on current NEC codes to clear up wire size and service issue | DIYALLTHETIME | Electrical | 2 | 03-05-2009 07:24 AM |
