Need Advice On Cleaning A/c Unit In My Condo - HVAC - DIY Chatroom Home Improvement Forum
Old 05-17-2009, 09:48 AM   #1
Question
need advice on cleaning a/c unit in my condo
Condo purchased 2-years ago.
A/C unit from 80's.
Unit blows fine, but there is NO cold air.
I cleaned the coils. Still blowing, but no cold air.
I used AC Flow Evaporator Coil Cleaner. It blows fine, the coils frost, but it is not blowing cold air. The coils are icing up in the air handler.
"To clean the coils, use an antimicrobial solution. When the solution turns the coils white, thoroughly rinse them with a garden hose. Follow the same procedure to clean the fan system (squirrel cage)"
I need to remove the squirrel cage. Is that difficult? Where would it be? I'm trying to find info on the DIY website.
If by chance I need Freon, how would I proceed with that-is that difficult to replace?
mellow_yellow is offline   Reply With Quote
Old 05-17-2009, 09:55 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 136
I would recommend you call a pro. It probably is low on freon and freon is not a DIY project as you need special tools, knowledge and usually a EPA license to buy it. At that age the compressor could be partially worn out and only a pro can tell you about it properly. If you try remove the fan and break it or cause a vibration you may regret it. An old worn unit will use LOTS of electricity $$ so you may want to have it assessed to find out its condition.
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
central unit will not come on ....please help guyasc HVAC 5 08-24-2008 05:10 PM
Show extractor unit advice jascot75 General DIY Discussions 1 04-08-2008 10:32 PM
