Old 12-27-2012, 01:48 PM   #1
I'm Your Huckleberry
Nebraska hvac.
Any techs on here in Nebraska? I'm in south Texas but have to travel up there to rework a 16 seer condensing furnace that was a poor install for my boss.
I've never installed a condensing furnace (heat pump and gas secondary) up in Nebraska, just wondering if there's anything I need to pay special attention to. Unit is located in attic and is supposed to me moved from one place in attic to another spot in the attic. Ducts and intake and exhaust piping and all will be reworked.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 12-27-2012, 02:07 PM   #2
Mod
kwikfishron's Avatar
Nebraska hvac.
Don't forget your Mittens.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 12-27-2012, 02:27 PM   #3
Hvac Pro
Nebraska hvac.
May want to take a translator. "What he do" may not make sense to dem up der.
Ben watchin too many COPS shows I have.
Old 12-27-2012, 05:23 PM   #4
An old Tradesmen
Nebraska hvac.
may have to insulate the exhaust pipe and the condensate trap and drain line. If its in an area that the temps drop below freezing.
Old 12-27-2012, 08:48 PM   #5
Nebraska hvac.
What would I use to insulate these pipes with? I do believe that the freezing condensate is already an issue.
Thanks.
Old 12-27-2012, 08:55 PM   #6
Nebraska hvac.
... what would you insulate a large suction line with...... ..
carmon is offline   Reply With Quote
Old 12-27-2012, 10:12 PM   #7
Nebraska hvac.
I have never seen an hvac system in an attic and there must be a reason for this.
First thing would be to take it out of the attic and put it in the basement or in a utility room on the main floor.
cleveman is offline   Reply With Quote
Old 12-28-2012, 12:19 AM   #8
Nebraska hvac.
doh! Thanks.
Thanks.
Old 12-28-2012, 07:31 AM   #9
Nebraska hvac.
Yep insulate the exhaust and self regulating heat tape on the trap and condensate line. Not too bad here right now Doc... highs are hitting almost 20 degrees and the lows are still above zero. Should be fun for a texas guy
What part of Nebraska you coming to?
Old 12-28-2012, 11:04 AM   #10
Nebraska hvac.
Here in Houston we don't have basements. Just about everything is in attics, even the hot water heaters.
Thanks.
Old 12-28-2012, 12:22 PM   #11
Nebraska hvac.
Highs in the 20's? I'm not too thrilled with that at all. Plan was to catch a bus to Dallas to meet up with the hvac company owner and drive in his truck up there to head honcho's place, but not sure what town.
We'll see if it's actually going to happen or not.
Thanks.
Old 12-28-2012, 12:36 PM   #12
creeper's Avatar
Nebraska hvac.
wuss
creeper is online now   Reply With Quote
Old 12-28-2012, 12:41 PM   #13
creeper's Avatar
Nebraska hvac.
I once lived in a rental home. The owner decided to have a furnace installed in the attic. It soon became apparent that the installer neglected
the small detail of the condensate drain.
The drywall on the ceiling came down in chunks.
Old 12-28-2012, 02:15 PM   #14
An old Tradesmen
Nebraska hvac.
Very common here.
Old 12-28-2012, 03:01 PM   #15
Hvac Pro
Nebraska hvac.
The ground water level may be high in a lot of areas so to dig a basement is impossible. Also basements cost a lot of $$ to dig and pour walls etc so to keep the house construction cost down attic units are used or crawlspace units too.
HELP!!! How much owe my HVAC repairman? Is he competant? MB1 HVAC 23 02-01-2012 03:42 PM
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 09:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 05:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
