Natural Heat Pump Idea - HVAC - DIY Chatroom Home Improvement Forum
Old 02-09-2009, 09:12 AM   #1
natural heat pump idea
Currently my two story home has a built out daylight basement, obviously the 'basement' is much cooler then the rest of the house. I have had a Idea I wonder if its worth my time.
I would like to put a hole in the intake for the heating system in the basement so that in the hot months I can turn off the intake upstairs and just pull cool air from the basement to the whole house. by running the fan only.
is this a good project?
spudgunman is offline   Reply With Quote
Old 02-09-2009, 11:22 AM   #2
The short answer is: it depends.
Ignoring any potential code issues, there are a few other things that you may want to consider. First is the fact that your air conditioner does more then lower the temperature of the air; it also lowers the relative humidity of the air. So while the air in your basement may be cool, it may also be relatively humid (which may only get worse with the A/C off). So you may not want to spread that around the house. The second thing is that if you basement has any odors, those two will be spread throughout the house.
Then there is the whole code issue. Many places won't let you use your basement as a plenum, which you are kind of doing here.
Dooz is offline   Reply With Quote
Old 02-09-2009, 01:24 PM   #3
Rewards Points: 484
The other problem is, the cool air in the basement would be gone in a matter of minutes.
sammy37 is offline   Reply With Quote
Old 02-09-2009, 02:04 PM   #4
thanks for the 411 - I have no AC or heat pump right now and likely wouldn't put one in for a long while as I have more pressing projects that want to get done. (like a hot tub)
Old 02-09-2009, 02:46 PM   #5
30 year tech
hvac122's Avatar
Also a safety issue to think about is this idea could put your basement in a negitive pressure and cause the hot water heater to backdraft among other problems like drawing in radon gases.
hvac122 is offline   Reply With Quote
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
Heat Pump "check light" comes on???? rockey HVAC 4 11-17-2008 05:02 PM
Easy Heat Pump Question brutis HVAC 6 11-03-2008 10:06 AM
Better for heat pump or electric coil/strip? Lori 48616 HVAC 5 09-05-2008 02:28 PM
Heat Pump Troubleshooting (Advice/Help) Drawknife HVAC 5 02-01-2008 02:41 AM
