Natural Gas Venting In Ontario - HVAC - DIY Chatroom Home Improvement Forum
Old 11-28-2008, 08:45 PM   #1
Natural Gas Venting in Ontario
What does the Ontario Building Code require in terms of distance to windows / doors when venting a natural gas appliance?
I have heard 6', however I do not have a single point on my exterior walls in which I can vent 6' away from an operable opening. The best I can do is a little over 3' horizontally from the main entrance and 1' from the garage door. The garage is attached and is sealed from the rest of the house by an exterior-type door and is unheated. So the garage door would not be considered an operable opening into the house as far as I'm concerned.
The manual for the unit advises 2' from any operable opening. It is a Bosch tankless water heater so it won't be running all that much.
Any info would be much appreciated.
Reilley is offline   Reply With Quote
Old 11-29-2008, 04:34 AM   #2
An old Tradesmen
Rewards Points: 7,362
Your local code enforcement office would be better able to tell you what is allowed.
I've had the inspectors come out to job sites to double check things before installing them on many occasions.
This eliminates headaches ahead of time.
Old 11-29-2008, 07:29 AM   #3
tk03's Avatar
Rewards Points: 150
I believe the 6' is for power vented products not direct vented products. As Beenthere stated check the local codes officials. If you need help I could make a phone call and find out Monday morning. I am sure the rep we have would know.
tk03 is offline   Reply With Quote
Furnace venting questions Mastiff HVAC 9 12-05-2012 05:51 PM
Venting a Cape properly - strange? k00k Roofing/Siding 2 11-11-2008 03:07 PM
venting a high efficiency furnace through the roof (how high) allAboutDIY HVAC 11 10-21-2008 12:48 PM
Blocked Attic Soffit Vents on North Side - How to Improve Venting Jes Roofing/Siding 5 05-06-2008 09:35 AM
Retrofit Horizontal Venting roughestcarpenter HVAC 3 01-16-2008 04:46 PM
