Natural Gas Valve - Low Pressure ? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2009, 11:23 PM   #1
Natural gas valve - low pressure ?
I have an older gas furnace with basic thermo. I can get the pilot lit while holding the pilot button down but within a few seconds the pilot fizzles and goes out. I can even turn the valve to on, pilot will stay on for a few seconds but befor I can get to the thermostat to turn it on, pilot fizzles. When I try to relite, no gas from pilot. I can wate a feww minutes and pilot will be at full pressue again. Help, Rick
rickfatannie is offline   Reply With Quote
Old 10-15-2009, 10:48 AM   #2
Rewards Points: 150
Sounds like the thermocoupler needs to be replaced.
TJ_in_IL is offline   Reply With Quote
Old 10-15-2009, 02:26 PM   #3
I slept on this problem overnight. I know that when you hold the pilot button down it is manually opening gas to the pilot, so there had to be a blockage to the valve. Maybe bad regulator outside? Went outside to check and found the gas line shut off. Turned on again, lit pilot, good flame working fine. Now, that valve was off all sumer but was allowing enough gas through to let pilot lite for a second or two. A little scarey don't you think???
Old 10-15-2009, 07:02 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,872
Left over gas in the line, not a problem.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 05:32 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
