Natural Gas Line Distance From Wood Stove Chimney - HVAC - DIY Chatroom Home Improvement Forum
Old 03-19-2014, 10:20 PM   #1
natural gas line distance from wood stove chimney
Hi,I'm planning to put a wood stove in my basement. The location is right under some gas flex line attached to the bottom of the floor joists. What is the minimum distance between a wood stove chimney(double wall) and a flexible gas line in my basement? Thank you for any advice
dfritz is offline   Reply With Quote
Old 03-19-2014, 10:54 PM   #2
Rewards Points: 2,516
Consult the National Fuel & Gas Code for all your answers.
hammerlane is offline   Reply With Quote
Old 03-20-2014, 06:38 AM   #3
Rewards Points: 242
double check what type you can use. over here code is triple wall stainless for a wood stove.
hvac instructor is offline   Reply With Quote
Old 03-20-2014, 01:59 PM   #4
Thank you for your advice!
Tiling Over Painted Wood Paneling for Wood Stove Insert MegMarkR1 Tiling, ceramics, marble 2 02-07-2012 12:45 PM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Intallation of wood stove in Garage radl2 HVAC 3 10-12-2009 09:21 PM
Building a base for my wood stove Verbose Building & Construction 1 10-11-2009 08:06 PM
Wood stove chimney partially obstructing 1st floor window-code? Badfish740 HVAC 3 09-02-2009 09:13 AM
