Natural Gas Line - HVAC - DIY Chatroom Home Improvement Forum
Old 03-31-2008, 10:25 AM   #1
Natural Gas Line
i need to run an underground natural gas line from my basement to unattched garage aprox 30' how deep should i trench and what type and size pipe would be used will only be supplying over head heater
bwhall@roadrunner.com is offline   Reply With Quote
Old 03-31-2008, 11:17 AM   #2
RippySkippy's Avatar
What's the BTU requirements of the furnace and in your location, can you do what you want, some places are very restrictive when it comes to running gas service.
RippySkippy is offline   Reply With Quote
Old 03-31-2008, 01:06 PM   #3
heater btu's 45000 was told could run line but wasn;t given any particulars i am in buffalo ny
Old 03-31-2008, 05:20 PM   #4
hvac/refrigeration
Southeastern code is a minimum of 12'' deep, I'm not sure there in Buffalo. And the size depends on which type pipe/tubing you use. 1/2'' galvanized pipe must be coated with tar , 5/8'' copper tubing will carry 45,000 up to 60', or 5/8'' plastic tubing will be cutting close by the time you go back up the wall to heater I would probably step up to 7/8'' on it. Also if you choose plastic it must have metal risers to come back to the surface.
metal-maniac is offline   Reply With Quote
Old 03-31-2008, 06:03 PM   #5
mm thank's for the reply i'll check on that 7/8"tubing first chance i get hope to have this complete within next couple weeks
Old 04-09-2008, 08:31 PM   #6
I ran 1" plastic to my detached garage in Ohio. I think it cost me about $150 for the tubing (75' of tubing plus the risers and clamps to attach the risers to the house & garage) My code for plastic I think was pretty deep, 30" if I remember correctly. The trencher made short work of it and having heat in the garage in the winter is well worth the hassle! Don't forget the copper tracer wire if you choose to use plastic. When filling in the trench I threw in phone & cable...
HVACman is offline   Reply With Quote
Running a natural gas line Roger General DIY Discussions 2 02-27-2009 07:42 AM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 07:49 AM
Demo of Natural Gas Line millipede Safety 3 11-13-2006 01:13 PM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
