Natural Gas Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 12:54 AM   #1
Question
Natural gas heat
Ok so my heat usually works just fine, but sometimes when the thermostat clicks on I hear the system humming like it's trying to start, but just can't.
Sometimes turning it off for a few minutes and back on does the trick, other times I have to boots the temp to say 78 when it's only registering 71 inside just to get it past the humming of trying to start to actually get it running.
currently at 78 it doesn't seem like it's even coming out all that hot atm. What can I do?
Hakushi is offline   Reply With Quote
Old 10-30-2011, 02:27 AM   #2
how
Rewards Points: 1,070
Heating systems are not generic. Brand name, style, model and year will make it more than a guessing game.
how is offline   Reply With Quote
Old 10-30-2011, 03:53 AM   #3
REP
The humming you hear,is that after the flame comes on ,or doesn't the flame come on.Without much info all we could say is check and make sure all electrical connectings are tight.Check and make sure you have 24 volts.Check ande make sure that the motor capsitor is ok.
Oh and when you are cdhecking for tight wires make sure you check the wires at the stat too.
REP is offline   Reply With Quote
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 09:30 AM
Goodman GPH1336H21AA heat strip connection jrajra HVAC 2 09-02-2010 05:52 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Heat Pump Woes Zenica HVAC 50 01-27-2009 08:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
