Natural Gas Furnace To LP? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 02:40 PM   #1
Natural gas furnace to LP?
I got a 40k BTU hanging furnace for my garage from a buddy (not even sure what I've got, I'll find out more when I get home) but didn't have a chance to get a gas line run to the garage before the ground froze. I'd like to get a 100lbs LP tank and run off of that for the rest of this year if I can. What's involved with converting? Will it cost too much to be viable for just one year? I don't absolutely have to have a heated garage, but... you know how it is.
qoncept is offline   Reply With Quote
Old 12-28-2009, 02:58 PM   #2
You need a LP conversion kit . Comes with a spring for the gas valve and new orifices.Gas pressure has to be adjusted properly. Last one I bought was less then $20
Old 12-28-2009, 03:31 PM   #3
Great, thanks! Are these universal? Hopefully, because this is a pretty old Modine furnace and I might have trouble finding one otherwise.
Old 12-28-2009, 04:14 PM   #4
They are not universal.
Old 12-29-2009, 09:22 AM   #5
It's worth opening up the thing and looking carefully.
My kitchen stove came with orifices for both LP and natural gas. The one's that aren't in use are stored inside.
pyper is offline   Reply With Quote
Old 12-29-2009, 10:01 AM   #6
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
Slightly off topic, but if you in place where the roads are salted during the winter and park your car in a heated garage, it will lead to accelerated corrosion.
random thought.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 12-29-2009, 08:07 PM   #7
You should locate the ID tag on that heater that has make and model and check with the manufacturer to see if there is a conversion kit available. 40k BTU isn't really a lot depending on the size of your garage and temperatures. Make sure that it is NOT a ventfree heater. They are not convertable.
log_doc_rob is offline   Reply With Quote
Natural Gas Furnace Limit Switch 04gt HVAC 5 12-12-2009 07:50 AM
Installing natural gas furnace in place of heat pump, please help KlamathMog HVAC 17 10-20-2009 01:55 PM
Natural gas forced furnace - Burner shuts off prematurely scooter100 HVAC 9 01-25-2009 10:46 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
