Natural Gas Furnace Limit Switch - HVAC - DIY Chatroom Home Improvement Forum
Old 12-10-2009, 06:27 AM   #1
Question
I have a 17 year old Tempstar 100,000 Btu input, 80% efficient natural gas furnace. Furnace works great except for when I raise thermostat setpoint by about 3 or 4 degrees and the furnace runs a while to get to the setpoint. After about 20 mins. the burners go out for about 30 sec and then reignite. I have confirmed with a voltmeter that the main limit switch is opening at this time. When the furnace runs for less time, no problems. Manifold gas pressure is 2 in h2o (3.5 in h2o is spec) and temperature rise is 50 degrees F ( 30-65 degrees F spec), clean non restrictive filter, all return and supply vents are fully open. Any other ideas?
04gt is offline   Reply With Quote
Old 12-10-2009, 05:48 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,816
Replace the limit control it is weak. When it trips it should stay off for several mins. It is weak and kaput.
Old 12-11-2009, 05:59 AM   #3
Thanks for the reply. I'll consider replacing the limit switch. I experimented more yesterday with my issue. I installed the foam type washable air filter that was in the furnace when I bought the house. Furnace ran fine for over a 1/2 hour with a constant 50 degree temp rise and never tripped the limit. I had been running a cheap blue fiberglass filter which I thought was about as non-restrictive as you could get. The house is about 50 years old and the furnace is 17 years old. Possibly the duct work is not optimal for the retrofitted furnace and its sensitive to airflow/filters?
Old 12-11-2009, 06:40 PM   #4
Hvac Pro
yuri's Avatar
You may want to get an experienced Pro to check the heat exchanger of that furnace. They are VERY prone to cracking and popping the compression rivets which hold them together.
Old 12-11-2009, 09:24 PM   #5
Doesn't Tempstar get product liability or wrongful death lawsuits? Especially if they know about it?
"Lennox, Tempstar and York have supporters, including James Dulley, but reliability is below average, according to the latest survey data (which is quite outdated). Dulley commends the Lennox two-stage model for quiet operation."
Old 12-12-2009, 07:50 AM   #6
Hvac Pro
yuri's Avatar
The heat ex have a 20 yr warranty and that covers them.
Installing natural gas furnace in place of heat pump, please help KlamathMog HVAC 17 10-20-2009 01:55 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
Natural gas forced furnace - Burner shuts off prematurely scooter100 HVAC 9 01-25-2009 10:46 AM
HEIL furnace keeps kicking off reset switch sunsetacres1318 HVAC 8 11-04-2008 08:35 AM
RUUD Gas Furnace Pressure Switch? erik11 HVAC 8 12-06-2006 11:39 PM
