Natural Gas Flow - HVAC - DIY Chatroom Home Improvement Forum
Old 03-27-2013, 02:37 AM   #1
natural gas flow
How do I check for natural gas flow
dcstewart6488 is offline   Reply With Quote
Old 03-28-2013, 07:20 PM   #2
Before or after the meter??(inside piping or from the main to your home)
From the main to your home you are probably on a UP, 15, 60 or 120 lbs. system( however all systems would actually run at less pressure)
A plumber can hook up a pressure guage after the shut off but before the regulator on you riser near your meter set.
Inside your home, a plumber can hook up a "U gauge" to determine pressure since it will be less then 16 "wc.
Stcrosby is offline   Reply With Quote
Old 03-28-2013, 08:52 PM   #3
DIY staff
Rewards Points: 7,174
Moved to HVAC----A better description of your concern will get you a good answer---
Old 03-28-2013, 09:00 PM   #4
how
Rewards Points: 1,104
Eating lots of beans always does it for me.
Give more details if you'd like a more specific answer.
how is offline   Reply With Quote
Old 03-29-2013, 07:18 PM   #5
Rewards Points: 610
run just one gas fired unit at a time..while it is running then you can time the input at the gas meter with a stop watch..the meter is in cubic feet per minute so, you time it for a minute and see how many feet the dial indicates (you might have to research how to read the meter)...there is one thousand BTU's per cubic feet...do the math...will be different if you have a metric meter...again, do the math...all of this woks only if you have a gas meter of course!
techpappy is offline   Reply With Quote
Old 03-30-2013, 07:06 AM   #6
Rewards Points: 582
well...one way is take off a cap and see if it flowing what are you wanting to do ..ben sr
Old 03-30-2013, 08:43 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Actually...chips and salsa does it well for me....toss in some beer and we can get some real velocity.
But if the op is talking about the gas line in his house....go to one of the gas appliances....turn off the gas using the shut off valve that should be there....remove the flex hose...momentarily turn on said shut off valve....gas should be flowing....
If said appliance does not have a local shut off valve.....stop...I would suspect there are some serious issues in this house.
ddawg16 is online now   Reply With Quote
Old 03-30-2013, 09:00 AM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 2,286
this should solve all your problems
Old 03-30-2013, 09:27 AM   #9
JOATMON
ddawg16's Avatar
Yuri...why would anyone need A/C in Winnipeg? I've been there many times.....usually freezing my a$$ off....one winter about 4 years ago....-47.6....it hurt....
So...how is the old Palomino club doing?
Old 03-30-2013, 10:06 AM   #10
Hvac Pro
yuri's Avatar
-47 yeah but that is in Winter. actually our Summers can get very hot and somewhat humid (60-70%RH, nothing like Florida though but we suffer at those levels). We even have a full blown desert in Carberry.
Palomino is still in biz but like the Urban cowboy and dinosaur may go extinct. There was a copycat to it that failed miserably but I guess there must be enough old Urban cowboys to support it so you never know.
hot water baseboard flow question (long) fred54 HVAC 4 10-14-2011 03:39 AM
radiator flow: connecting IN and OUT lines, yay or nay? amakarevic Plumbing 2 10-06-2011 01:31 PM
Jacuzzi tube does not flow water!! Nate53 Plumbing 0 09-16-2011 08:14 PM
Second Floor Vent Has No Air Flow somewhatsketchy HVAC 7 08-16-2010 12:32 PM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 05:05 AM
