Natural Gas Fireplace - HVAC - DIY Chatroom Home Improvement Forum
Old 03-01-2016, 11:42 PM   #1
Rewards Points: 117
Is it possible to add a thermostat to a unit although it originally did not come with one??
mustang64 is offline   Reply With Quote
Old 03-02-2016, 12:02 AM   #2
how
Rewards Points: 1,104
Usually only fireplaces with powerpiles can handle the extra electrical resistance of the added thermostat & gas valve connections. There is also a limit to how long a length of thermostat wire you can run.
Older units with only thermocouples supplying the power.....can't use a thermostat!
I'd suggest supplying us with close up photos of your gas pilot and the electrical connections at the gas valve.
how is offline   Reply With Quote
Old 03-05-2016, 05:10 PM   #3
Rewards Points: 117
Here you go.
Old 03-05-2016, 05:12 PM   #4
Rewards Points: 117
Another photo.
Old 03-05-2016, 06:27 PM   #5
how
If you get at least .400 DCMV between your two TP gas valve connections when the gas valve is not in the "on" position, then you should have enough power to run a thermostat circuit up to 20 ft. with 18 gu wire.
Take the red line off the gas valve TH connection and connect it to one of your two new thermostat lines.
Take your other thermostat line and connect it to the TH connection on the gas valve where the red wire formally was.
This will allow the gas valve to be controlled by the thermostat while keeping the safety limit circuit intact.
Make sure all the wiring connections at the gas valve and the thermostat are tight and that your connection of the red wire to the stat wire is both tight & well insulated against touching any grounding metal.
The Following User Says Thank You to how For This Useful Post:
supers05 (03-05-2016)
Old 03-05-2016, 06:47 PM   #6
Rewards Points: 46
Take your other thermostat line and connect it to the now empty TH connection on the gas valve.
Make sure all the wiring connections at the gas valve and the thermostat are tight and that your connection of the red wire to the stat wire is both tight & insulated against touching any grounding metal.
Just to add;
This will NOT power a stat. So any stat that runs off r+common are off the table without extra wiring. (this includes the nest and ecobee) You will have to use a stat that will work solely off of batteries. (many Honeywell stats, sensi, etc.
Cheers!
supers05 is offline   Reply With Quote
Old 03-05-2016, 07:09 PM   #7
how
@supers05
Yes..I was assuming that he was just going to use a simple mechanical thermostat.
Old school habit.
Old 03-05-2016, 07:43 PM   #8
Rewards Points: 7,918
Mechanical stat is best.
Actually an old school mercury switch stat is best if you can still get one; the contacts of mechanical switches can oxidize over time, causing a voltage drop. It's insignificant on a 120v or even 24 circuit, but for something running on <1v could cause erratic operation.
My Backround FIY: I am not in the business of any trade or topic I give advise on. I have some have formal education in HVAC + some DIY experience. Theory is not a substitute for experience.
user_12345a is online now   Reply With Quote
Old 03-05-2016, 08:33 PM   #9
Usually Confused
lenaitch's Avatar
Rewards Points: 1,958
I was asking my dealer the same thing a while back and he said they have an aftermarket thermostat with remote. Apparently the 'receiver' replaces the on/off toggle switch. Didn't get the brand and I haven't got around to looking further into it. Our problem is there is no reasonable was to run a hardwired thermostat. Our unit is an older Napoleon.
lenaitch is offline   Reply With Quote
Old 03-06-2016, 01:06 AM   #10
Rewards Points: 46
I've seen more then enough fireplaces just like the OPs that use a regular toggle switch. The wires and terminal plates on a plain Jane toggle switch corrode much sooner then the contacts. (a bit of filing and it's good as new)
Cheers!
Old 03-06-2016, 11:55 AM   #11
Was assuming a t-stat is a given; was just saying that mercury style switch would probably be better than mechanical snap action. I don't think they make mercury stats any more; they wouldn't pose a problem if people disposed of them properly.
Natural gas fireplace vanilla-thunder HVAC 2 12-29-2015 12:32 PM
water leak into natural gas fireplace nico6196 Roofing/Siding 5 05-19-2014 09:39 AM
Natural stone veneer on fireplace surround Paul8434 Concrete, Stone & Masonry 2 03-10-2014 06:01 PM
Odor / Stink from new direct vent natural gas fireplace after 30 hours of burning cnauta HVAC 18 01-05-2014 10:31 PM
New parts for Natural Gas Fireplace jasesun23 HVAC 0 04-19-2013 04:49 PM
