Old 01-27-2009, 12:16 PM   #1
Nat. Gas Bioler... Power vent won't shutoff
I believe the system is a Teledyne Minitherm but can't verify till I get home. This a condo and the flue vent with the assist of a squire cage fan to the out this is now running 24/7 I think it is supposed to shutoff right? if yes what might be wrong (air pressure switch)?
Many thanks
gauol is offline   Reply With Quote
Old 01-27-2009, 12:49 PM   #2
Not much info to go on, I suspect it is a relay sticking. Does the burners still fire up too? Are you getting heat? Need more info.
SKIP4661 is offline   Reply With Quote
Old 01-27-2009, 12:50 PM   #3
JohnH1's Avatar
I belive the minitherm is a natural draft furnace. Is this a add on sidewall exaust kit? and yes the should shut off.
JohnH1 is offline   Reply With Quote
Old 01-27-2009, 01:35 PM   #4
Hi guys thanks for the quick replies
SKIP4661
The burners are still firing and I am still getting heat the only thing that seems to be wrong is the fan that exhausts the system is running non-stop. As I noted I'm not at home currently but is some other info I can to you when I get there?
JohnH1
I'm fairly certain this a minitherm I am 100% confident that it is power vented either way
Thanks Again
Old 01-27-2009, 02:21 PM   #5
JohnH1's Avatar
JVH is draft indused the JVT and JVS are natural draft. here is a link to the info. http://www.laars.com/webDocs/docDownloads/1086H-NH.pdf
Old 01-28-2009, 02:58 AM   #6
so hopefully i've attached a couple of files that show the system i'm working with.
The first pic is the fan the is always on
and
the second photo is the model a JVT so I think this mean it supposed to be natural draft but from what you can see it is being power assisted
Nat. Gas Bioler... Power vent won't shutoff-photo-1.jpg   Nat. Gas Bioler... Power vent won't shutoff-photo-2.jpg
Old 01-28-2009, 06:24 AM   #7
An old Tradesmen
I don't see a control set up from the water heater.
So it is probably set up to run 24/7.
Old 01-28-2009, 09:46 AM   #8
hope these help i think it shows the water heater control
and
the relay doesn't seem to be physically stuck as does move when the kill switch is thrown
Nat. Gas Bioler... Power vent won't shutoff-photo-3.jpg   Nat. Gas Bioler... Power vent won't shutoff-photo-4.jpg
Old 01-28-2009, 11:33 AM   #9
JohnH1's Avatar
Both the boiler and water heater can turn on the induser. Both have a indipendent switch to turn it on. The water heater pressure switch may be stuck. Try lightly tapping on the round switch at the base of the water heater were the wires attach. I cannot tell were the switch on the boiler is that controlls the induser. Again lightly you dont need to beat on it.
Definetly get it fixed that thing running 24/7 is going to kill your gas bill.
Old 01-28-2009, 11:35 AM   #10
JohnH1's Avatar
I also do not see the required spill switch safetys at eather divirter on boiler or water heater. Have that chech and corrected if needed.
Old 01-29-2009, 10:18 AM   #11
so i think found the problem the pipe leading from the air pressure senor switch was pinched closed I opened it up a little and everything seems to be working now.
Thanks for all the help
Old 01-29-2009, 03:20 PM   #12
I have an unrelated (and probably not important) question from the pictures. Shouldn't all those pipes coming out of the boiler be insulated? Or are they in a living space so it doesn't make that much difference?
scowl is offline   Reply With Quote
Old 01-29-2009, 03:22 PM   #13
The guy who lived here before never insulated them but i plan to. a buddy of mine at work is going to bring some spare insulation at home that he is going to let me have.
Old 01-29-2009, 03:40 PM   #14
An old Tradesmen
6 one way, half a dozen the other way.
They are losing heat to that area.
They are also keeping that area warmer, so the water heater doesn't run as often as it would if they were insulated.
Old 01-29-2009, 04:16 PM   #15
Unless the heat escapes to other areas which it tends to do.
draft vent motor for Duomatic Olsen HMS72-D sparky296 HVAC 2 01-10-2009 12:02 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
Noise from boiler power vent den HVAC 2 03-03-2007 08:10 AM
Direct Vent Vs Power Vent APPY HVAC 1 02-15-2007 11:26 AM
Is my furnace a direct vent or power vent? wease HVAC 5 02-02-2007 08:55 AM
