Narrowing Down My Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 10-27-2011, 08:47 PM   #1
So. Since I tried testing for power in nearly every spot in my furnace, I still can't figure out whats bad. BUT.
If I hook up a 24v DC/AC power supply to the pos and neg to the gas valve and then hardwire the fan switch, it blows hot air like it should.
Now what could cause this? There's so many relays in here I don't know where else to look or what part needs to be replaced.
colu41 is offline   Reply With Quote
Old 10-27-2011, 09:22 PM   #2
biggles's Avatar
you have a standing pilot with a copper capillary screwing into the gas valve from a thermocouple sensing the pilot flame..when you call for heat it just sits no main gas and the fan will run only after the heat builds up in the chamber as designed...
Old 10-28-2011, 06:35 PM   #3
So what does this mean? And if I leave the fan switch plugged in, how long will it take for it to heat up and turn the fan on?
Old 10-28-2011, 07:29 PM   #4
If your best idea involves hard wiring a gas valve you should probably cut off your gas and call a HVAC contractor. I'm all for sharing information, but you appear to be dangerous enough without it!
brandonmcginnis is offline   Reply With Quote
The Following User Says Thank You to brandonmcginnis For This Useful Post:
Marty S. (10-28-2011)
Old 10-29-2011, 04:52 AM   #5
An old Tradesmen
Rewards Points: 6,906
You may have a safety that is open. And it may have opened to prevent your death. Please don't hard wire your gas valve.
Post brand and model number of your furnace. A pic may help also.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (10-29-2011)
Old 10-29-2011, 09:47 AM   #6
It's a Coleman 7900 Series. It's in a mobile home.
Old 10-29-2011, 09:53 AM   #7
An old Tradesmen
probably an open flame roll out switch. Check for continuity across all safeties.
Old 10-29-2011, 09:56 AM   #8
Posting pictures in a minute.
Old 10-29-2011, 10:18 AM   #9
Sorry for the pic size. Came straight off my phone. Where do I locate this Rollout Switch?
Old 10-29-2011, 01:31 PM   #10
where is the Flame Rollout Switch on my furnace? I was actually told by a few different people that this sounds like the problem so I would really like to find it and test it. Found one for $9 online so I hope that's it.
Old 10-29-2011, 02:06 PM   #11
An old Tradesmen
Follow the blue and white wires of the gas valve. One will go to either a flame roll out, or a centrifical swith on the inducer.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 08:04 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 12:01 AM
