Mystery Circuit - Between Air Handler And Thermostat. What Could It Be??? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 09:59 AM   #1
Mystery circuit - between air handler and thermostat. What could it be???
Hi,
I'm trying to come up with some possible theories of what kind of circuits could exist between a thermostat wire and air handler??
Summary:
- forced air electric, 2 zones
- Zone 1 is main house
- Zone 2 is wing of house controlled by a separate thermostat that actuates a damper to redirect air handler output to that wing of the house.
Zone 2 works fine, but when tracing the thermostat wiring for Zone 1 there appears to be some kind of circuit in the thermostat wiring somewhere well outside of the air handler. Whatever this circuit is, it's not easily accessible/identifiable. The thermostat wiring runs right alongside zone 1's hot air outlet duct.
(ie With Zone 1 thermostat wiring disconnected at AH and Thermo I measure 2 ohms red to red but 185 ohms white to white. That suggest possibly a relay coil???)
What possible circuits could be in line between a thermostat and air handler. Maybe a second damper?? What else is common??
hennyh is offline   Reply With Quote
Old 06-09-2012, 11:09 PM   #2
Msradell's Avatar
Rewards Points: 122
The only thing I could think of would be an additional damper. That's very normal in a two zone system so that either zone can call for heat/air while the other one is satisfied.
Msradell is offline   Reply With Quote
Old 06-10-2012, 07:36 AM   #3
An old Tradesmen
Rewards Points: 6,500
Probably a zone panel.
Air handler blower will not come on? davvid20120 HVAC 8 04-01-2012 01:55 PM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 02:17 PM
Problem with Air Handler wiring connection to Outdoor Unit & Thermostat miamikk HVAC 0 09-29-2009 08:02 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
