My Unit Is A Dinosaur - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 06:49 PM   #31
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
The most you get out of any properly working electric element is 4500-5000 watts which is no different than (3) 1500 watt oil filled radiator heaters from HDepot. That is an add on heater and obsolete and probably unsafe to use IMO. I have seen lots of electric elements short out/arc and have had electric furnaces catch on fire. Usually the wire melts and burns up B4 the main 100 amp or larger fuses or breaker trips. Can do considerable smoke damage to your house. I would get some of those heaters as they are quiet, cheap and will do the job 4 U.
Old 12-18-2012, 08:52 PM   #32
Rewards Points: 484
I have a feeling even if the heat worked properly, that they have bigger issues than just the unit.
There are a few of those ground mounted over/under setups around here and what makes the whole thing worse is the return runs under the slab and is severely restricted and the supply running up the inside of the wall is only about 8 inches deep. I removed one from a house a few years back because it never cooled or heated the home and installed a new side by side unit on the roof and cut in a proper sized ceiling return, it was like night and day.
sammy37 is offline   Reply With Quote
The Following User Says Thank You to sammy37 For This Useful Post:
yuri (12-19-2012)
Old 12-19-2012, 08:55 AM   #33
Hvac Pro
yuri's Avatar
Thats good you are telling her that. Modern units with direct drive blowers won't handle that undersized ductwork very well and the old belt drive would just groan but not have the same problems. Sounds like your roof unit is the best option.
Tags
artic circle , heat pump , heat strip , packaged , thermostat
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 10:24 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 05:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 04:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 08:50 PM
