My Trane A/c Wont Cool - HVAC - DIY Chatroom Home Improvement Forum
Old 06-25-2011, 01:07 PM   #1
Question
My Trane a/c wont cool
i have a trane xe 1000 outside and the trane xe 80 inside. it hasnt been cooling the last 3 days, the fan outside and the one inside are both turning. there is also a continously blinking light on the diagnostic. have also noticed lights in house dimming since this started 3 days ago. also when u turn it on it wont shut off i guess thats because it not cooling. any help wpould be appreciated dont have the money to call anyone in. my daughter and i are frying in these 105 temps here in oklahoma. hope someone can tell me how i might fix it myself. thank you
laynes is offline   Reply With Quote
Old 06-25-2011, 01:55 PM   #2
JJboy's Avatar
You have to check capacitor and ohming the compressor. Do you know how to use multimeter?
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-25-2011, 02:22 PM   #3
Not much to go by from your post. You need to check to see if the compressor is running, and check to see if the freon charge is OK, if you do not know how to do this, call a tech.
clocert is offline   Reply With Quote
Old 06-25-2011, 02:44 PM   #4
An old Tradesmen
Rewards Points: 6,152
As the others said. And if you continue to let it try to start like it is. You WILL burn out the compressor.
Tags
a/c , electrcicty , hvac
Trane TCONT803 Tstat install ... on Trane XB14 system chaaalie HVAC 10 09-08-2011 07:56 AM
Trane Heat Pump Problems (heat instead of cool) leesimmonds HVAC 12 03-22-2011 05:23 AM
Ruud vs Trane peter_holmes HVAC 23 07-28-2010 03:32 PM
Outside Trane - heating and air unit- blowing cool air inside home but not getting below 85 degrees Leatha HVAC 1 07-25-2010 08:32 PM
new install of Trane XL15i nind HVAC 32 01-30-2010 01:59 PM
