My Temp Sensor Works, But The Furnace Not Blow The Heat, No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 01-06-2012, 01:02 AM   #1
My temp sensor works, But the furnace not blow the heat, no heat
My temp sensor works, But the furnace not blow the heat, no heat. I mean no fire at the bottom of the furnace. No gas smell.
may18 is offline   Reply With Quote
Old 01-06-2012, 02:17 AM   #2
how
Rewards Points: 1,102
Age/brand/model of furnace would help.
Are you saying that your thermostat works but your furnace doesn't fire up?
how is online now   Reply With Quote
Old 01-06-2012, 06:48 PM   #3
biggles's Avatar
red emergency switch is UP/ON ...service switch side of furnace is UP/ON...shut the servcie switch off.remove the stat off the subbase and jump R to W unscrew one screw to other....that is a constant heat calll...down on the furnace toggle up/ON the service switch ...tell us what happens...is it a standing pilot,see a glow...hear a sparking sound like your stove burner....filter is clean
Old 01-06-2012, 09:57 PM   #4
REP
OK I'm confused.If you have no fire,how do you know your sensor is working.
When the thermostat is calling for heat,do you get 24V to the gas valve?
REP is offline   Reply With Quote
Replace Heat Exchanger or Furnace deccher HVAC 41 10-22-2013 09:45 PM
Upgrades for my old electric furnace? alochin HVAC 6 09-11-2011 07:09 PM
Leaking Heat Exchanger in Furnace - Heat On Brentimus HVAC 1 03-19-2011 10:42 PM
Heat pump vs. Furnace and Air Conditioner heating&cooling HVAC 11 06-16-2010 07:07 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
