-   -   My temp sensor works, But the furnace not blow the heat, no heat (http://www.diychatroom.com/f17/my-temp-sensor-works-but-furnace-not-blow-heat-no-heat-128992/)
may18 01-06-2012 01:02 AM
My temp sensor works, But the furnace not blow the heat, no heat. I mean no fire at the bottom of the furnace. No gas smell.
how 01-06-2012 02:17 AM
Age/brand/model of furnace would help.
Are you saying that your thermostat works but your furnace doesn't fire up?
biggles 01-06-2012 06:48 PM
red emergency switch is UP/ON ...service switch side of furnace is UP/ON...shut the servcie switch off.remove the stat off the subbase and jump R to W unscrew one screw to other....that is a constant heat calll...down on the furnace toggle up/ON the service switch ...tell us what happens...is it a standing pilot,see a glow...hear a sparking sound like your stove burner....filter is clean
REP 01-06-2012 09:57 PM
OK I'm confused.If you have no fire,how do you know your sensor is working.
When the thermostat is calling for heat,do you get 24V to the gas valve?
