Is My New Variable Speed Air Handler Working Correctly? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2012, 03:31 PM   #1
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 95
Is my new variable speed air handler working correctly?
Hey, guys.
Got an Amana 3-ton variable speed split system installed for the upstairs of the house last week. Fired it up for the first time on Saturday night.
With the fan set to "on", I get a nice slow air movement. But as soon as heat is called for, it's like a wind tunnel hits. The way I expected the variable fan to work is that it would use less blower speed when only a degree or 2 are called for. I expected that this would require some additional wiring to the thermostat. The installer sold me on getting a Nest thermostat. It is wired for "heat pump - heat" and "heat pump - cool". I can get the exact wiring for you if it would help. I don't believe he ran new thermostat wire so he likely only used the leads that the old system's wire made available.
So.. what's the deal? A forum search leads me to the ComfortNet thermostats, but that cant' be the only way to get the variable fan speed to act smarter, can it? I don't need to control the speed directly, I just want it to be smart about when it uses differing speeds. Can I use the dip switches I see mentioned?
Thanks!
inK
Hammer in Hand, Dad on Speed Dial
http://www.mydadsshoes.com
ink is offline   Reply With Quote
Old 11-26-2012, 04:42 PM   #2
An old Tradesmen
Rewards Points: 6,140
Nest stat can't control the fan speed. Good chance the installer didn't set up the blower right. However it will still ramp up fairly fast when ever there is a heat or cooling call.
Old 11-26-2012, 04:47 PM   #3
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 95
The wires hooked up are:
Y1, G, O/B, RC, C
Interesting tid-bit from the Nest support pages:
"Note: By default, Nest controls the fan in the same way for each stage of heat based on what is selected during setup. A Nest Certified Professional, however can configure each stage individually using Pro Setup"
inK
Old 11-26-2012, 05:27 PM   #4
An old Tradesmen
Need more then 5 wires to have any fan control.
Tags
amana , nest , variable speed
variable speed trane blower motor afn63537 HVAC 25 01-13-2013 06:31 PM
Carrier Hi 90 Furnance variable speed motor ahenderson HVAC 0 12-18-2010 08:28 AM
Is my AC working correctly? Snoop101 HVAC 4 07-18-2010 10:34 PM
Trane XV80 - low speed fan not working oregondean HVAC 4 01-12-2009 01:46 PM
Wiring of my two-zone system not working correctly AMontemagni HVAC 3 01-27-2007 01:07 PM
