My New Humidifier Not Working Well - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-04-2011, 11:20 PM   #16
Rewards Points: 460
Yuri-
Can a new current sensing relay be inserted as in diagram 5?
Then the fan setting would turn on the furnace blower and humidifier?
http://www.alpinehomeair.com/related...20Diagrams.pdf
also: if humidifier is on supply side, does humidistat go on the return side?
diyorpay is offline   Reply With Quote
Old 02-05-2011, 07:40 AM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 1,144
Originally Posted by diyorpay View Post
Yuri-
Then the fan setting would turn on the furnace blower and humidifier? Fan setting? not sure what you mean. Poster has a DC ECM variable speed motor which has to be controlled by the circuit board
Yesss
Old 02-05-2011, 08:40 AM   #18
An old Tradesmen
Rewards Points: 6,132
Humidistat always mounts on return when duct mounting it. Since 70 degree air at 45% RH when heated to 120 degrees would only be an RH of 10%.
Honeywell HE260A Humidifier install rdtour HVAC 3 02-02-2011 10:10 AM
Help - I need my humidifier working when blower is on, not just heat canuck88 HVAC 15 01-02-2010 04:31 AM
Aprilaire humidifier stopped working Richo HVAC 2 11-19-2009 08:28 PM
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 08:42 PM
AprilAire 550 Humidifier not working? mcvane HVAC 2 11-22-2008 12:15 PM
