My Mixed Whatever Heating System - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2015, 01:43 PM   #1
Rewards Points: 4
My mixed whatever heating system
I just moved into my "new" house and for the past few days the heater will not go over 58 degrees til about 1pm. It utilizes hot water to provide heat so I tried letting hot water in the kitchen trickle overnight but that did not help, any suggestions? Thanks
qzone23 is offline   Reply With Quote
Old 01-02-2015, 01:56 PM   #2
how
Rewards Points: 1,070
fuel type/ brand/ model/,,,,details for the telepathically challenged here.?
how is offline   Reply With Quote
The Following 3 Users Say Thank You to how For This Useful Post:
ben's plumbing (01-02-2015), hvactech126 (01-02-2015), oldbikes (01-02-2015)
Old 01-02-2015, 05:58 PM   #3
Rewards Points: 4
Goodman Manufacturing, model ACH2423-1, electric water heater supplied
Old 01-02-2015, 06:51 PM   #4
how
So is your home being heated entirely from an electric tank slaved to an air handler that lists a heating capacity of between 16,000 to 36,000 BTUs?
Old 01-02-2015, 07:13 PM   #5
Plumber & Gasfitter
Rewards Points: 77
Pictures? House size and location? Water tank size? Does the tank provide hot water for domestic use and space heating?
joeplumber85 is offline   Reply With Quote
Old 01-02-2015, 08:15 PM   #6
Rewards Points: 3,498
Are you certain that your space is heated by a electric water heater?
roughneck is online now   Reply With Quote
The Following User Says Thank You to roughneck For This Useful Post:
Old 01-02-2015, 11:15 PM   #7
Rewards Points: 1,910
Where are you measuring the 58 degrees? Is that the room temp, the air temp coming from the blower? What is the water temp when it's working well and not working well?
When it's not working well is heater running but blowing cool air or is the heater just not running?
What are the specs on the water heater? Does the water heater also provide your hot water for kitchen and bath water. How big is your house and about where are you located?
Do you have a programmable thermostat?
Old 01-03-2015, 12:02 AM   #8
Rewards Points: 4
Temp read at programmable thermostat, max water temp of 180 min 140, 860 square foot, water heater supplies all hot water which always runs extremely hot, when only reading 58 only cool air coming out of vents until approx 1pm and I am in northern Nevada
Old 01-03-2015, 01:18 AM   #9
So when it's blowing cold air the actual water temp is 140 degrees or more? Is it set to blow all the time (manual) or only when calling for heat(auto)? Just as a sanity check make sure the programmable thermostat is set properly and calling for heat before 1PM. I know it sounds obvious but sometimes those things can unintentionally get set wrong.
Do you know if it was working better before? What's the kwh rating on the water heater? It's possible the water heater doesn't put out enough btus to supply your domestic hot water useage as well as heat. Trickling the hot water won't help. it will hurt by using up some of the water heaters output.
Old 01-03-2015, 01:36 AM   #10
The unit you have is often run in combination with a heat pump. Is yours? If the hydronic isn't working and the heat pump is you might get the results you describe. You might only be getting heat from the heat pump in the afternoon when the temps warm up. When it is cold at night and in the morning the unit should be trying to use the hydronic when the heat pump can't keep up. Can you check to see if the hydronic pump is operating? There is typically a relay that kicks on the pump. Do you feel comfortable checking the relay to see if it's getting voltage when it should and whether it's putting out power to the pump?
Old 01-03-2015, 01:41 AM   #11
Rewards Points: 4
programmed to 65 degrees but for some reason it cools down to 58 around 2 am and like I said before it doesn't heat up again until around 1pm. this only started around three days ago. also, when it runs in the early morning it is cycling constantly for at least 4 hours as if it is trying to heat my house up but the air is cool
Old 01-03-2015, 07:11 AM   #12
An old Tradesmen
Rewards Points: 6,072
Is the circulator running while when the house gets cold.
Old 01-03-2015, 02:07 PM   #13
Rewards Points: 4
Yes it is
Old 01-03-2015, 04:52 PM   #14
An old Tradesmen
Look to see if there is a box from the electric company shutting your water heater off at peak times. Or a mechanical timer.
Lights continually flicker while heating system running bshep Electrical 1 02-16-2014 10:11 PM
Pipe Sizing for Hot Water Heating System tmguinan HVAC 7 09-23-2012 08:59 PM
Open Hydronic Heating System... how / need to bleed? MtnMan7 HVAC 1 11-19-2010 04:51 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 04:26 PM
old heating system jtb003 Plumbing 2 01-30-2010 09:48 PM
