My Hvac New Motor , Now Quit - HVAC - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 09:38 PM   #1
Unhappy
my hvac new motor , now quit
I replaced a 1/6 HP motor on my outside unit a week ago with a 1/4 HP motor bc the bearing was to bad. The unit has a two speed two stage start capacitor for the fan and compressor. This was checked and was good at motor installation. The unit now quits in ax mode and only the inside blower works. I cut everything off for bout 15 min and cut on and outside unit started fine. Any thoughts on this scenario.it is American standard bout 12 yrs old
roofie is offline   Reply With Quote
Old 06-23-2011, 10:07 PM   #2
JJboy's Avatar
Did you replace the capacitor?
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 06-23-2011, 10:11 PM   #3
Have not replaced it as of now, only found problem little while ago. When I put the motor in one company told me to replace the capacitor and the electrician told me that if it checked out good there was no need in replacing.
Old 06-23-2011, 10:54 PM   #4
JJboy's Avatar
only If the capacitor has the same value.
Old 06-24-2011, 04:40 AM   #5
An old Tradesmen
Rewards Points: 7,746
I don't think electricians work on A/C units/systems. So I wouldn't really listen to their advise on how to service them.
What was the amp rating on the old motor, what was the RPM of the old motor? Is the new motor the same amp and RPM rating as the old motor? Is it spinning the right direction?
Tags
cool , hot , hvac
Runaround - HVAC and HWH proper venting/exhaust denemante HVAC 24 04-05-2011 08:50 PM
moving HVAC system - can I go without gas for a few days? denemante HVAC 2 03-30-2011 04:55 AM
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 07:28 AM
Engineered Joists & holes for HVAC ducts walt1122 Building & Construction 3 07-04-2009 07:37 PM
new HVAC & door bell quit didn'tdoit HVAC 3 04-16-2006 06:30 PM
