My Humidifier Is Not Humidifying - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2008, 07:47 PM   #1
sweaty
Rewards Points: 276
My Humidifier is Not Humidifying
I just got a Carrier Infinity heat pump and love it. Now that it's heating, the air has gotten dry enough that my kids are coughing at night and getting nosebleeds. According to the controller, it is set for 45% ( the highest it will go) and reads 54% in the house. Yet my kids have this problem and I also feel it in my nose and throat. What do you think?
Also, the manual for the humidifier says it needs to be tapped off a hot water pipe. It comes from a cold pipe. What do you think?
sweaty is offline   Reply With Quote
Old 11-03-2008, 08:16 PM   #2
54% should be plenty high enough for the current temps. If the humidifier says it needs to be hooked up to a hot water supply, then it really should be. There's been a few threads lately on humidifiers so try searching past threads.
jerryh3 is offline   Reply With Quote
Old 11-04-2008, 07:49 AM   #3
An old Tradesmen
Rewards Points: 6,152
Controller could be reading wrong.Get another hydrotherm and check it.
Humidifiers don't work real well on heat pumps if they aren't connected to the hot water.
Are you using the Infinity controller.
HVAC Humidifier Question rubicon789 HVAC 8 01-13-2009 12:06 PM
Help with humidifier walker45 HVAC 15 01-04-2008 11:02 PM
Fiber board duct & humidifier BigD HVAC 1 12-26-2007 07:04 AM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 09:04 PM
HVAC humidifier issue rfjm58 HVAC 4 04-12-2007 07:46 PM
