My Home Ac Unit Works Only When Fan Is Set To On, Why? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-30-2011, 02:53 PM   #1
My home ac unit works only when fan is set to on, why?
I have a Goodman rooftop package unit. The problem I have is only one. The A/C only works when the fan is set to ON and not on Auto. When set to AUTO, I hear the A/C compressor humming for a few seconds then always immediately stops humming, and the fan never turns on. When I set the thermostat to Heat and set to FAN AUTO, the fan turns on after a few seconds when I call for heat. Why doesn't my fan turn on when I call for A/C?
Skytramm is offline   Reply With Quote
Old 04-30-2011, 03:23 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
sounds like the relay in the t-stat is sticking or another problem in the t-stat. IF you set the fan to on and the blower runs, then I would start by replacing the stat. If the blower does not run when you set fan to auto then it could be in the control board of the package unit
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-30-2011, 03:23 PM   #3
JJboy's Avatar
I think your thermostat is the problem.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Home ac unit summergirl5432 HVAC 2 04-01-2011 05:54 PM
Help us make a remodel decision for selling home pleas 3detailer Kitchen & Bath Remodeling 11 04-27-2010 11:36 AM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
