My Heil Furnace Does Not Always Start Up - HVAC - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 09:57 PM   #1
My heil furnace does not always start up
I recently purchased a furnace and had it installed , however after a couple of months it has decided to randomly not turn on when the temperature drops. The temp inside the house has dropped as much as 6 degrees before the furnace has kicked back on. I have a honeywell digital thermostat and even if we increase the desired temp only the blower starts up then after a couple of minutes shuts off. this is totally random it may work all night then stop in the morning or work all day then stop an hour before I go to sleep. I thought it may have been over heating because of limited return air but I added a small return. maybe this isnt enough I dont know but I could use some advice.
mike_d is offline   Reply With Quote
Old 12-16-2010, 09:59 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
look for a diagnostic led through a window in the blower door when it's acting up
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-16-2010, 10:02 PM   #3
if your describing that circular window on the lower panel I did it was off there was no light. and when it happens there is no flame on the upper rectangular window.
Old 12-16-2010, 10:04 PM   #4
AKA HVACTECHFW
no light means you can't see it because the window is notoriously not lined up with the led, or a bad board, or no power
IT IS WHAT IT IS
Old 12-16-2010, 10:07 PM   #5
ok so how do i line up the led with the window.
Old 12-16-2010, 10:08 PM   #6
AKA HVACTECHFW
if you are diagnosing the furnace (only while diagnosing) remove door and tape door switch.
IT IS WHAT IT IS
Old 12-16-2010, 10:13 PM   #7
sorry for my ignorance but when you say diagnosing are you suggesting that I turn the furnace off before removing the panel.
Old 12-16-2010, 10:17 PM   #8
AKA HVACTECHFW
when I say diagnosing, I mean don't just run your furnace with the door off.
IT IS WHAT IT IS
Old 12-16-2010, 10:50 PM   #9
ok i see the light the furnace is working now. its blinking green. so i will check tomorrow if it goes out again and check the diagnostics.
Old 12-18-2010, 05:48 PM   #10
Ok so it went off again and the light blinked 3 times which indicates that there is a pressure switch that is open when it should be closed. how do i locate the pressure switch. Is it inside one of the panels or on the outside of the unit.
Old 12-18-2010, 06:42 PM   #11
An old Tradesmen
Rewards Points: 6,458
Doubt the pressure switch is the problem. That switch is a safety. Might want to ask the installer to come and look at it. Since it should be under his 1 year warranty. Unless he installed it with no warranty.
You may have an improper vent issue.
Heil Gas Furnace Not Lighting kasi42 HVAC 21 10-09-2010 05:40 PM
Furnace won't fire, exhaust fan hot and won't start tex800 HVAC 14 10-08-2010 07:48 PM
clare furnace needs reset to start dustin020 HVAC 2 10-15-2009 07:06 PM
Heil furnace inducer vibrating, capcitor handling question diggerdave HVAC 45 03-01-2009 05:56 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
