My Gas Heatpump Wont Work - HVAC - DIY Chatroom Home Improvement Forum
Old 09-09-2012, 09:40 AM   #1
my gas heatpump wont work
i have a carrier gas heat pump and it was working fine until we turned the gas off and fixed a hole in the line, the line is repaired and my stove which is also gas works fine now my heat pump wont work it runs but no heat do i need to do something where it was shut off or it being a self lighter should it light itself?
tammyc is offline   Reply With Quote
Old 09-09-2012, 01:34 PM   #2
An old Tradesmen
Rewards Points: 6,498
Was the gas line to the furnace purged.
Old 09-09-2012, 07:07 PM   #3
Hi, the unit may have locked out on the circuit board if unit is equipped with this feature as beenthere said purge gas line free of air first . once done reset unit and see what happens .
hvac dude is offline   Reply With Quote
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 08:14 PM
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 12:53 PM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 03:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 07:09 PM
