My G26 Lennox Furnace Tries To Start For About 5 Seconds Then Shuts Down - HVAC - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 08:11 PM   #1
My G26 Lennox furnace tries to start for about 5 seconds then shuts down
The furnance doesn't even try to ignite. The blower kicks on for about five seconds then shuts down right away. I dried out the manifold. I'm not getting any failure indications for the controller.
hawkeye2011 is offline   Reply With Quote
Old 03-25-2011, 08:35 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
ensure you have a continuous 24V between W and C at the control board during a call for heat. Could possibly be a stat issue. Or a board issue.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-25-2011, 10:33 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Do you have a drip leg on the gas line just before it enters the furnace? There is debris in the gas lines feeding the burners so that can clog the gas valve in the furnace by not allowing gas or the correct amount of gas into the burners. That scenario would resemble low gas pessure or it could be no gas pressure if completely clogged. If no gas to produce flames is present than your blower will immedately shut off as the flame sensor isn't detecting flames like it should thus it will cut the blower off as it has no business being on if there are no flames in heating mode. Makes sense, huh?
Just thinking aloud of the possibilities, especially without any code. The no flash code could be the board itself, as already stated by tech126, but if the control call for heat drops out there would be flash code, again, if the board is working properly.
Have you paid your gas bill?
Doc Holliday is offline   Reply With Quote
Old 03-25-2011, 10:44 PM   #4
AKA HVACTECHFW
there would be no flash code if you are losing a call for heat from the stat
IT IS WHAT IT IS
Old 03-25-2011, 10:48 PM   #5
I have a fully functioning Carrier gas furnace that I use for troublehsooting (and for playing around to scare my dog and cat ) sitting directly in front of me in my living room that states if the call for heating drops out than the flash code is 11, on short and one lang flash.
I just figured it would be the same for all brands..?
Old 03-25-2011, 10:50 PM   #6
make that flash code 12.
Old 03-25-2011, 11:07 PM   #7
AKA HVACTECHFW
maybe you should post when you know the answer for sure...... Code 12 refers to a carrier/payne/bryant ONLY!
not meaning to come off as a jerk, but lets give the people with problems good solutions not theory based on sparse experience.
IT IS WHAT IT IS
Old 03-25-2011, 11:57 PM   #8
Sorry tech126, you caught me completely off gaurd, we'll try again tomorrow.
Old 03-26-2011, 01:03 AM   #9
Registered User
Rewards Points: 5,482
Welcome to the forum, hawkeye2011!
Hopefully you will get the problem solved soon! Anymore pertinent information that would be relevant to solving this, guys?
Gary
Old 03-26-2011, 01:29 AM   #10
how
Rewards Points: 1,104
I agree with hvactech126... board or stat problems because of the clear led display. Remove the thermostat connections (R & W) on the furnace and jumper (R & W) to bypass the thermostat. If the furnace fires up you know its a stat or thermostat wire problem. If the furnace doesn't fire up then it will require at the very least, board repairs (unlikely) or more likely replacement of the board.
how is offline   Reply With Quote
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
Gas Furnace Won't Stay Running / Thermostat Set High To Start _scott HVAC 6 03-23-2011 07:27 PM
Lennox Furnace Model #: 90UGFA3-75-6 GauravJ Electrical 0 10-29-2010 06:52 PM
Lennox G11Q3E-110V-6 gas furnace neato5oh HVAC 1 10-07-2006 06:43 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 06:10 AM
