My Furnace Keeps Cutting Off - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 04:17 PM   #1
My furnace keeps cutting off
Hi, I have an older Rheem gas pac (model RRGG-10E30JKR) that just quit heating this morning. I removed the front cover and found a reset button popped out, and reset it. (I think is a fuel metering valve but, not sure since I don't know much about HVAC) It cycled through a couple of times then lit, and burned for 2 or 3 minutes, and shut back down. There is small fan just above that that is running all the time also. Can someone point me in the right direction on what could be wrong, or where to start my diagnostics?
Thanks, Alan
prealan01 is offline   Reply With Quote
Old 11-07-2012, 06:10 PM   #2
An old Tradesmen
Rewards Points: 6,460
Could have a cracked heat exchanger.
Old 11-07-2012, 06:17 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
Yep. A manual reset is usually on a limit control and they don't pop for no reason. If it is a rollout switch or limit control that can be a very dangerous situation so you want to get it checked by a Pro and stop resetting it.
Old 11-07-2012, 06:39 PM   #4
That sounds expensive, thanks Yuri, and beenthere.
Old 11-07-2012, 06:45 PM   #5
Hvac Pro
yuri's Avatar
Thoese units are prone to cracking and carbon buildup in the heat exchanger causing CO poisioning and flame rollout ( gas packs ).
Old 11-07-2012, 06:49 PM   #6
Good to know, I will get in touch with a contractor to get it checked out. thanks
Old 11-07-2012, 07:04 PM   #7
Rewards Points: 582
yep agree older rheems around here had high exchanger rate failure....get that one checked by the pros....ben sr
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
