Closed Thread
Old 01-31-2009, 11:01 PM   #31
hvaclover's Avatar
Thought you said that little black motor was running. It's called an inducer. Is it running or no?
Just slow, not stupid.
hvaclover is offline
Old 01-31-2009, 11:03 PM   #32
I didn't say that. Is there anyone else here we can ask ?
Lucky Strike is offline
Old 01-31-2009, 11:04 PM   #33
hvaclover's Avatar
Is it running or not?
Old 01-31-2009, 11:06 PM   #34
no it doesn't run.
Old 01-31-2009, 11:09 PM   #35
hvaclover's Avatar
You are going to need a volt meter. Do you have one?
Also you started the thread with "Furnace blows cold air". Is the blower running right now?
Old 01-31-2009, 11:13 PM   #36
I have a volt meter and yes the blower blows cold air through the registers. Is the little black motor the blower ? If it is then it must be running because air blows through the registers. It just looks kind of small to be blowing air through the registers. I thought it was to cool something down in the furnace.
Old 01-31-2009, 11:15 PM   #37
hvaclover's Avatar
Old 01-31-2009, 11:19 PM   #38
What do you mean ?
Hey guy I understand if you can't figure out what is wrong with the furnace . It's not a big deal. I would just appreciate it if you could point me towards a site or someone on this site that understands gas furnaces a little more.
Old 01-31-2009, 11:23 PM   #39
Hey bud thanks a lot for your time. I got to get going and get this thing working. I'll let you know what the problem was when I find it out.
Old 01-31-2009, 11:27 PM   #40
First he says it's the ignitor and then he asks if the inducer motor is running then he posts funny faces when he can't find the problem. Thanks for the misdiagnosis, later
Old 01-31-2009, 11:42 PM   #41
hvaclover's Avatar
Can't tell you what's wrong if you insist on being vague.
Old 01-31-2009, 11:47 PM   #42
hvaclover's Avatar
I said it was the igniter when you said the inducer was running. I mis understood because you answer with vague responses.
Sorry, but I'll let somebody else help you.
Old 02-01-2009, 08:18 AM   #43
Journeyman
Here is the sequence of operation
pipefitter636 is offline
Old 02-01-2009, 08:36 AM   #44
An old Tradesmen
Have you been changing your air filters regularly.
If the blower turns on in less then 30 secends.
You probably have an open high or aux limit.
Control board should be flashing an error code.
Look for it.
beenthere is offline
Old 02-01-2009, 11:18 AM   #45
I am not expert here either, but by reading this thread you have been very vague in your answers. There are hundreds of different makes and models of furnaces and they all work a little different than other units.
Without details, these guys cannot help you with specific answers.
You may need to call a local HVAC guy to come and diagnose the unit since you dont seem to be able to answer these guys questions.
They don't get paid to be here either.
-Andrew
DIY hobbiest
AndrewF is offline
Closed Thread
More On This Topic
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
Alright, we're answering questions and I want to talk for a minute about if someone asks you a question that is very, very, very long. Alright, there are really two things that you need to do in order to answer this extremely lengthy question. Always say... Read More »
Flooring cold from furnace intake flipper_79 Building & Construction 1 01-25-2009 01:24 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 03:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
add vent/move cold air return CamL HVAC 0 03-22-2008 10:45 PM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 02:00 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
