Closed Thread
Old 01-31-2009, 10:30 PM   #16
hvaclover's Avatar
Never mind. Just being cautious.
Just slow, not stupid.
hvaclover is offline
Old 01-31-2009, 10:31 PM   #17
Is there anyone else that can help me out ?
Lucky Strike is offline
Old 01-31-2009, 10:32 PM   #18
hvaclover's Avatar
http://www.dnmech.com/lit/Good_GMP_SS186ce.pdf
Old 01-31-2009, 10:35 PM   #19
Originally Posted by hvaclover View Post
I won't understand that , is there anything you can just tell me to check on it ? Right now it is sitting here with the blower running. When I flick the switch on and off it hesitates for a second then I hear a couple of clicks and the blower turns on but I never see the gas light.
Old 01-31-2009, 10:36 PM   #20
hvaclover's Avatar
Does the furnace make any of the usual running noises right now or did you turn it off.
Just for giggles turn the stat all the way up and pull the top panel off the furnace.
The link above is for your furnace.
Old 01-31-2009, 10:37 PM   #21
hvaclover's Avatar
Gimme a second to check the PDF I posted.
Old 01-31-2009, 10:39 PM   #22
I did it. I hear some clicks then the blower starts then after a little bit I hear a couple more clicks but blower stays running.
Old 01-31-2009, 10:40 PM   #23
hvaclover's Avatar
Bad igniter.
Turn the furnace off and on one time.
Old 01-31-2009, 10:41 PM   #24
Take your time I appreciate your help very much. I looked up your profile someone has said that you are good at this. Take your time.
Old 01-31-2009, 10:42 PM   #25
Bad igniter.
That is what I been doing hoping something would reset it. I'll go do it again. BRB,
Old 01-31-2009, 10:43 PM   #26
hvaclover's Avatar
Bad igniter.
Read my quote. That's the problem.
Old 01-31-2009, 10:45 PM   #27
hvaclover's Avatar
The igniter needs replacing.
Old 01-31-2009, 10:48 PM   #28
How do you know ?
Old 01-31-2009, 10:57 PM   #29
Is the little black motor suppose to be running ? When does that turn on ? After it lights ?
Old 01-31-2009, 11:00 PM   #30
Just wondering I thought I remembered it running before it ignites usually. I might be wrong.
Closed Thread
More On This Topic
Hi, my name is Shotsie Gorman. I'm here as a tattoo artist (a professional tattoo artist) for Expert Village. We're taking the client. He has decided he wants to place it centered on the back between the scapula or the "wing bones". That's what people... Read More »
Hi, my name is Shotsie Gorman. I'm here as a tattoo artist, a professional tattoo artist for Expert Village. See now, if I hadn't done that, that exterior line just would be gone. And I would have no clue where that is. Alright, we're going to go back in... Read More »
Hi, my name is Shotsie Gormon. I am here as a Tattoo Artist, a professional Tattoo Artist for Expert Village. It can be, if you have the time and the inclination and the client is interested in doing a unique way of tattooing, you can actually let the... Read More »
Hi, my name is Shotsie Gorman. I'm here as a professional tattoo artist for Expert Village. It depends on the tecnique; the Japanese would take very similar needle configuration to this, except it would be curved on the front on a stick and they would... Read More »
Hi, my name is Shotsie Gorman. I'm here as a tattoo artist, a professional tattoo artist for Expert Village. The mark is going along this line. Can I scratch down here? Yeah. See if no ink were in there. Right, no pigment at all. Then it would be... Read More »
Flooring cold from furnace intake flipper_79 Building & Construction 1 01-25-2009 01:24 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 03:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 03:45 AM
add vent/move cold air return CamL HVAC 0 03-22-2008 10:45 PM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 02:00 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
