My Furance Wont Stay On HELP! - HVAC - DIY Chatroom Home Improvement Forum
Old 01-15-2009, 04:58 PM   #1
my furance wont stay on HELP!
my boyfriend and I are broke. for the time being we are using kerosene in our oil furance. I known its probly not good for it but we have 4 kids, and can't afford the 300 dollar oil bill. we can't seem to figure out what is wrong with it. I know nothing about furances, so if someone could point us in the right direction it would be great. the furnace wont turn on using the thermostate. we manually turn it on, but it only last a few minutes before the burner shuts off, and the blower turns on. we bled the lines to see if that would help but it hasn't. please help.
kahnegirl is offline   Reply With Quote
Old 01-15-2009, 06:14 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
Hate to break the news to you but that furnace MUST use proper fuel oil. It may have some serious problems now and need a major overhaul. The nozzle, filter, pump etc may be plugged with crud and the chamber wet with bad fuel. This may start on fire and get out of control and cause a house fire. Find a warm place to stay (relative etc) and get a Pro to look the unit over and be prepared for some serious $$ expense. Sorry. Don't keep resetting it as that is VERY dangerous. Sorry
Old 01-15-2009, 06:55 PM   #3
is there a way that we could replace the nozzle ourselves. That's what we thought was wrong with it. and how much money are we talking about. we were told that it was okay to use the kerosene if we ran out. Is it really that bad.
Old 01-15-2009, 07:33 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 650
Ayuh,...
I doubt your choice of fuel has Anything to do with the problem,...
#1 fuel oil is a direct replacement for #2 fuel oil....
How Handy is your boyfriend,+ does he have any Tools,..??
The 1st thing to Check,+ Change is the fuel filter...
It'll be mounted somewhere between the fuel tank,+ the furnace,..Just follow the fuel line to find it...
Theres a bolt on top, 7/16" or 1/2" wrench, that'll release the filter housing,..
Change it, then, Rebleed it,+ Try it...
Bondo is online now   Reply With Quote
Old 01-15-2009, 07:52 PM   #5
An old Tradesmen
Rewards Points: 6,586
#1/Kerosene, is just a clean and slightly lower heat content oil
Sometimes it tends to clean the crude out of oil tanks.
Problem is, you may have created a dangerous situation.
If it has been spraying oil in the combustion chamber everytime you pressed the reset button.
When it does light off again. Your going to have a fire you won't be able to control.
Ask friends and family members if they can help you with teh repair bill.
Its better then having your children injured, or worse happen to them in a fire.
Old 01-15-2009, 09:23 PM   #6
tough situation, dont know what yall do for a living but you could try offering your services for the repair bill (barter), or ask a church.when theres kids involved most will help they have funds put away for just that reason you just have to be humble and ask for help. just a thought...repairing it yourself if you dont know what your doing can have disasterious results post up where you live perhaps someone on here lives nearby and can helpgood luck
kennzz05 is offline   Reply With Quote
Old 01-16-2009, 12:09 PM   #7
all of your suggestion were very helpful. I live in western new york. And we have thought about getting help from heap but were may make to much. My boyfriend has a very good job, But we have alot of bills and 4 kids. If anyone knows of help please let me know. we could pay for it to be fixed but only if its not that much. does anyone know how much it may cost.
Old 01-16-2009, 04:52 PM   #8
An old Tradesmen
No way to know.
We don't know what is wrong, let alone what a company will charge for the parts or labor.
LG Dryer DLG2526 won't stay lit Winchester Appliances 2 01-03-2009 06:53 PM
Carrier won't stay lit kurto HVAC 10 12-13-2008 02:50 PM
Lights stay on wsixsmith Electrical 19 08-05-2008 07:43 PM
Ventless gas fireplace vs. Home furance Dougit General DIY Discussions 6 01-05-2008 05:01 PM
