My Fridgidaire Furnace - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-29-2010, 03:57 PM   #16
An old Tradesmen
Rewards Points: 8,184
Plugging one or two of them. Does pose risk/dangers.
Since there is no way to control the air fuel mix after that is done.
EG:
If the furnace heat exchanger cells each are to be pulling in .33 CFM of gas and 16.66CFM of air when all burners are on.
When 1 or 2 burners are plugged. It will cause the cells of the 2 that aren't plugged to pull less air.
Old 01-29-2010, 04:24 PM   #17
Guess there's nothing I can do about regulating the temperature on this furnace. Thnk you so much for all your counsel on this Beenthere!
Flamshooter is offline   Reply With Quote
Old 01-29-2010, 04:25 PM   #18
An old Tradesmen
Nothing other then increase air flow. By adding more duct work.
Old 01-29-2010, 04:26 PM   #19
Yep, sounds like that is all we can do.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 07:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
