Old 10-25-2009, 03:26 PM   #1
Default My first post! HVAC problem...
A few weeks ago, I noticed the a- coil was froze up and shut it off to let it thaw out. Went back to turn it back on and; nothing. Checked all connections and am getting power to all but the rocker switch (on-off-auto). Got power from black to white when connected them, but not when the red terminal was involved. I don't have a Fluke or anything like that, so I was using a circuit tester (red and black wires and a light) I'm curious as to whether the blower motor is going bad, the thermostat is going out, or what the problem is.
Any help will be appreciated highly...
Deano2450 is offline   Reply With Quote
Old 10-25-2009, 04:02 PM   #2
Master Plumber/Mechanical
Look at the control board for evidence of water that has dripped on the control board.
It would also help if you would post brand and model
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-25-2009, 08:24 PM   #3
Nordyne
Model # E1EB-Q15HA
While I was looking at the model numbers and such, I remembered that a friend told me if I didn't have a volt meter that I could test the motor by jumping the red and black or red and yellow at the auto-fan-on rocker switch. So I did that and the blower came on. I'm guessing all I need is the switch? The old one has no indentions. You know, on-click/ off-click/ auto-click? Three way switch, right? It's a "no way" switch right now. I can't use just any type from an auto parts store?
Old 10-25-2009, 08:57 PM   #4
Not finding this model number
Is this in a mobile home?
Where is this switch located?
Old 10-25-2009, 11:32 PM   #5
Yes, it's in a mobile home.
The switch is mounted on the same panel that the blower is mounted to.
Old 10-26-2009, 06:37 AM   #6
a switch is a switch is a switch,any single pole double throw should do. as long as the amperage rating is correct
kennzz05 is offline   Reply With Quote
Old 10-30-2009, 05:52 PM   #7
I replaced the switch and now the blower will run, but only in the "on" position. In the auto position, no matter what I have the thermostat set on, it will not come on. Bad thermo?
If it comes out right, I've attached a pic of the guts of the thermostat.
Old 10-30-2009, 07:06 PM   #8
First take the wires off of your thermostat. Then take a jumper wire and jumper the red wire and the white wire on the thermostat. This should cause the heat to come on. If you jumper red to green the fan will come on. If you jumper red to yellow, the ac should kick in outside. If those things happen then you know your thermostat is bad.
thehvacguy is offline   Reply With Quote
Old 10-31-2009, 01:56 PM   #9
OK. I'll try that.
Wait. Do I have remove all the wires from their terminals and then jumper them?
More On This Topic
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Your home's heating and air conditioning system (HVAC) is one of the most important elements involved in enjoying your home. Besides providing a comfortable environment, your HVAC also helps to maintain your health by protecting you from extreme... Read More »
Hi I'm Doug. I work with twenty great guys in Saint Louis at Doug Jenkins Custom Hot Rods and we're going to do some work for you today on Expert Village. Now we're going to clean up the thermostat housing itself. Don't use sandpaper. We're using a roll... Read More »
Hi, I'm Lorin Parker for Expert Village, and we're building an oscillator on a bread board. So let's take a look at our bread board. Basically the bread board allows us to connect up rows. So if I stick a wire in here, these are my, where I have a red... Read More »
Today we are replacing a bad thermostat. Now once you have it removed from the wall, you’ll have to scrape this and repaint it, I’m sure. But you want to make sure to get the right thermostat because you can cause some damage to your A/C or... Read More »
Deck Post Height for Composite Post Railing ylwdog Building & Construction 4 03-22-2009 09:15 PM
goodman HVAC problem...only runs on AUX mode kerbear413 HVAC 1 12-03-2008 01:51 AM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 08:26 PM
Fence Post Problem cdubim Building & Construction 3 03-12-2007 03:09 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
