My Delemia - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2008, 07:41 PM   #1
Rewards Points: 150
My delemia
OK what I want is a specific stage control where my second stage wont come on untill I have an outdoor temp below 20 and both zones all calling at once, preferabley the outdoor temp sensor is adjustable. I have thought about the 4 zone zone first board which is the only zone staging board I have used ( as far as I know honeywell dosent make one) but that board doesnt have an outdoor temp sensor terminal , so I would have to frankinstein in a second board just for that. and before somebody mentions it pro8000 with odts wont work with the zone first board because it only has w2/L on the equip strip, any way this is a 90k job with eff as the only reason we are there so if any body has seen or worked with a designed board that can handle my specs I would appreciate it
geo fan is offline   Reply With Quote
Old 08-25-2008, 05:41 PM   #2
Rewards Points: 150
Thanks anyway figured it out actualy pretty cheap and eaisy real duhh moment
Old 08-25-2008, 09:51 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
What did you use?
Old 08-26-2008, 05:29 AM   #4
Rewards Points: 150
honeywell duel fuel heatpump board with outdoor temp sensor equip output to resistance coil goes though 2 normally open rib relay's in series engergized in parralell by the 24 v output for each zone damper
Old 08-26-2008, 07:35 AM   #5
jbfan's Avatar
Rewards Points: 138
That was what I was gonna suggest to use!
