Well, I think I know the answer so kind of looking for an affirmation or some small miracle that I overlooked something .
So a relative of mine had HVAC problems with no cool. They called a tech out and he said the condenser (outdoor) unit compressor is dead and needs to be replaced.
Skeptical that a 5 year old unit would die like this (given how common compressor failure misdiagnoses is) I went to check it out for myself.
The symptom is, the condenser immediately trips the breaker whenever cool is called for. Just trips over and over again every time it is reset.
When I get there to look at it, I noticed the suction line insulation going into the unit is soaked (I mean soaked) in refrigeration oil.... 1st thought was uh-oh leak somehere in these brazed joints.
The capacitor(s) "looked" fine in that it wasn't exploded or bulging.
To cut to the chase, disconnected the leads running to the compressor (verified with the schematic) and measured the resistance....
This is what I got:
56 ohms between the start and run winding.....
56.5 ohms between the start and common.
.8 ohms between the run and common.
The .8 ohms suggests it is fried......
Yes/No?
Did I miss anything?
Thanks......
This is what I got:
Yes/No?
Thanks......
