Old 02-07-2008, 06:07 PM   #1
Is my Comfortmaker electric furance toast?
I have a Comfortmaker electric furnace. A previous homeowner had an Aprilaire all-house humidifer installed directly above the fuse panel. Although I have had the humidifier disconnected since I bought the house 5 years ago, (no water flows through it) it appears that water dripped onto the fuse panel when the previous owner had it hooked up.
Last week the furnace stopped working and my HVAC repairman said the fuse panel has "heavy water/burn damage" and needs to be replaced. He got the system up and running temporarily by replacing the fuses. Problem is, he said the company no longer makes this fuse panel as a replacement part and that I would need to replace the furanace all together.
I'm just trying to verify if this is true - do I need a new furnace or is this part still available? The number my HVAC man gave me is DEBD020GBV. Serial number on the furnace (I believe) is SNL923735070.
Any help/advice would be greatly appreciated. Thank you!
Nels0213 is offline   Reply With Quote
Old 02-07-2008, 07:04 PM   #2
biggles's Avatar
if you can remove the exsisting fuses/box and mount a new fuse panel right where the old one was.then run the power wires into the new box with new fuses and bring the heater wires into it.if the old one is part of the unit completely bypass it with new stuff...12" to the left or right top to bottom won't effect the heater power for remounting the new box and extending the wires.the house power should be easy to swing away and reconnect...it is the heater wires into the new box location that has to be done right.
Electric radiant heat in the garage art2670 Flooring 4 01-26-2008 09:58 AM
electric oil boiler? for hot water? jamesdart Plumbing 2 01-13-2008 09:06 PM
Ventless gas fireplace vs. Home furance Dougit General Discussion 6 01-05-2008 05:01 PM
electric furnace need help Unregistered HVAC 3 10-16-2007 03:41 AM
Convert from electric heat to oil/propane? Badfish740 HVAC 7 05-15-2007 12:17 PM
