Is My Coil Drain Pan Rated For Oil Furnace? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-02-2010, 07:19 PM   #1
Is my coil drain pan rated for oil furnace?
I have a thermopride oil furnace with an A-coil for AC. The outdoor condenser was replaced 5 years ago. I never replaced the indoor coil until now due to a leak. I got an uncased a-coil online and had a local contractor put it in for me. I got the size and to match the condenser and measurement to fit into the plenum. However, I overlooked the higher temperature from Oil Furnace might melt the drain pan. The coil I got is ADP HE33436A155A004 uncased A-coil. From their website regarding to the type of drain pan on their coil:
"UV resistant drain pans are molded of high temperature (450 deg. F) engineered polymer"
Is this good enough for my oil furnace? Or should I swap out a different drain pan with a higher temperature rating?
TIA!
Dave
camg042 is offline   Reply With Quote
Old 07-03-2010, 08:08 AM   #2
Will be fine. Furnaces don't run that hot.
Old 07-03-2010, 08:22 AM   #3
thanks, that makes me feel much better. Do you know the normal running temperature at plenum for gas and oil furnace?
TIA!
Dave
Old 07-03-2010, 08:35 AM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 396
The supply air temp in the plenum is usually around 150 degF. Limit control set at 170-250 degF depending on model. Doubt if it could ever get that hot. I have seen them melted if the limit control was bypassed or failed. Do a temp rise test and speed up the fan if necessary. Run the furnace for 10 mins, stick a accurate cooking thermometer in the duct a foot downstream of the plenum and out of visual sight of the heat exchanger. Subtract the return duct temp from the supply. Look up the rating on the model # info sticker.
oil heat furnace coil RAMAN62 Plumbing 1 05-09-2009 07:08 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Replacement furnace, add AC coil now?? NJ user HVAC 5 02-05-2009 07:45 AM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 10:56 AM
